Traction Control Off - Terrible Sound and Rear End Hopping
Old Oct 22, 2008 | 10:31 AM
Redline_Burner's Avatar
Redline_Burner
Default Traction Control Off - Terrible Sound and Rear End Hopping
I tried searching for this but I have no idea what to call it ...
When I feel doing some back road wheel spinning starts from a stop I shut the TCS off and let it go. The tires spin, but then it's like there is still something keeping the wheels from just spinning. What is this? Is it just tire hop or is there a system keeping you from spinning the tires to your hearts desire? I've got an '07 Enthusiast, so obviously includes an LSD.
I think I've heard someone talk about a system that is there to keep you from doing drifting or straight-line burnouts, but the part I don't understand is that I can slide the car out in a wet parking lot with the TCS off and then there is no wheel hop/electronic leash to stop me. (I like to practice so I can get a feel for what the car will do if a skid comes up in real driving). So why won't the car do a straight line burnout but it will do "drifts" (For lack of a better term) all day long?
Flame if you want, but I'm new to the Z world so I'm just trying to get to know my car a little better.
Old Oct 22, 2008 | 11:12 AM
gothchick's Avatar
gothchick
Check ur sway bar & traction bar settings
Old Oct 23, 2008 | 06:33 AM
Redline_Burner
So the wheel hop type feeling isn't an electronic limiter at all?
Old Oct 23, 2008 | 07:00 AM
bhk1004's Avatar
bhk1004
well, i think the power is still limited, why dont you pull your rear brake light fuse out and give it a go? this is what i need to do to get the car to do a burn out. something about the car still limits power even with the traction control off.
Old Oct 23, 2008 | 08:02 AM
j.arnaldo's Avatar
j.arnaldo
Does turning the VDC and/or Traction Control off provide benefits on the MPG department? Why do some dudes turn them off? Down here it rains so often, I wouldn't do it.
The power decline could mean a tune-up's needed. Timing?. Clogged injectors?
Old Oct 23, 2008 | 08:51 AM
bhk1004's Avatar
bhk1004
trust me and try it with the rear brake light fuse out and let me know how it goes.
and for why people turn off the traction control, its because our traction control isnt very ummm nice? its very obtrusive and j ust immediately turns the power down at the slightest moment of slip or whatever. thats why alot of people turn them off, but its also caused accidents cause its off, like in rain/cold weather when the tires keep sliding.
Old Oct 24, 2008 | 06:03 PM
Redline_Burner
The car's brand new. It's an 07 with 2400 miles on it. (yes, 2400). So I don't think a tune up is needed. I will try taking out the rear brake light fuse out, but I assume that will kill my brakes lights correct? With the way car wiring goes sometimes I wouldn't really call that an obvious question.
Old Oct 24, 2008 | 09:25 PM
Im thinking friction between the tire and road surface.
Old Oct 24, 2008 | 10:36 PM
go-fast's Avatar
go-fast
check for a leapus in your trunk
Old Oct 24, 2008 | 10:55 PM
Motormouth's Avatar
Motormouth
^what the last two said, ignore everyone else. the wheel hop is NOT from traction control, do not pull your brake fuse and forget about your sway bars. completely ignore 2-6.
wheel hop is common. it's a weird inbetween of 'burning out' (spinning) and gaining traction.. the suspension movement causes the wheel to start bouncing or skipping if you will... like if you've ever drug your shoe across a floor and had it skip/grab/skip/grab you will know exactly what the car is feeling.
this is very bad for your car, stop doing it. your VLSD will not help with this issue. your tires could be worn, too high air pressure, you simply are giving it too much gas before it has traction, etc. it just comes down to traction. modify how you feather the clutch/launch the car and you will eliminate the problem. there is nothing else to be done except swapping parts.
I eliminated wheel hop I got from having lowering springs by getting coilovers, changing the tires, alignment and getting solid differential bushings. my car never hops now. it spins, or it grabs. very predictable.
Old Oct 24, 2008 | 11:25 PM
go-fast's Avatar
go-fast
if your rear suspension is too stiff you will shock the tires on launch.the tires will literally bounce off the pavement.if you watch pro stock cars leave at the track you will see the car actually squat and suck down towards the ground when launching.this is what you want.
Old Oct 25, 2008 | 11:12 AM
bhk1004's Avatar
bhk1004
i guess you dont know about the fact that the Z still kills some power to the wheel when it spins lets say during burn outs or whatever even when you turn off the traction control. its very well documented... unless something changed for the newer model.
Old Oct 25, 2008 | 12:11 PM
Motormouth's Avatar
Motormouth
no offense man, but that has nothing to do with his problem, and will not help it.
and you guess I don't know about it? lol.
Old Oct 25, 2008 | 01:05 PM
ekelly36's Avatar
ekelly36
Base model plus lsd ftw
Old Oct 26, 2008 | 06:16 AM
oneflyasianguy's Avatar
oneflyasianguy
^what he said.
i would look into a stiffer suspension setup.
Old Oct 26, 2008 | 07:23 AM
AZ350Z's Avatar
AZ350Z
The solid diff mount mentioned above makes a world of difference eliminating wheel hop. SPL sells a solid aluminum mount for $119. You have to drop the diff to install it, but it is a GREAT mod.
Old Oct 26, 2008 | 09:28 AM
Motormouth's Avatar
Motormouth
Originally Posted by oneflyasianguy
^what he said.
stiffer suspension can make it worse.
and yes: SPL solid diff bushings are the bomb. they were so nicely made and had a great price. the install (did it myself with a friend) was the biggest pain in the *** ever, but totally worth it.
Old Oct 26, 2008 | 12:01 PM
go-fast's Avatar
go-fast
if the car is new,try installing springs from an earlier car.i'm willing to bet they are plentiful.even if the spring ratings are the same,a used spring will not be as crisp.this might sort you out.
Old Oct 26, 2008 | 01:14 PM
dryseals's Avatar
dryseals
Wheel hop is part of your rear suspension set-up. As your tires spin forward, the rear differential will try and twist the opposite direction, or in othe words, the pinion angle will raise towards the body of the car. Some one earlier mentioned the prostock and that they squat, all cars will try and squat, the squat is what you do not want to happen.
An independent suspension is the worst for trying to tame, it's good for cornering but bad for launching. Your typical dragster will use the twisting action of the differential to apply lift to the front of the car (ladder bars) which in turn puts more pressure on the rear. Our cars do not have this.
A solid diff mount woud help, but make for a rougher ride.
PS, if you really want to spins the tire, get a cheap harder rubber tire, they'll spin easier.
Old Oct 26, 2008 | 01:36 PM
Motormouth's Avatar
Motormouth
What are you talking about? Firstly, you absolutely want squat in a suspension. The squat is rearward transfer of the weight of the car and results in increased traction. why do you think ultra stiff race cars have such terrible 60ft times? it's a compromise between purposes but EVERY car for any purpose is made to have squat. from the race car that needs it to launch out of a corner to the drag car that needs it for launch.
Secondly, harder rubber can exacerbate the problem as the grip profile leads to loss of traction. You want grip not slip and I don't think the OP was wanting to spin at all.
Thirdly, solid differential bushings in NO WAY lead to a harsher ride. The only negative aspect is increased gear whine transmitted through the chassis. You get more consistent handling better lateral traction and force the suspension to act more positively. the car has soft bushings between the subframe and the frame that absorbs the harshness.
so your whole post was wrong, and leads members to the wrong conclusions. don't do that.
In a related note to a post someone made: a VLSD will not help your car on launch. They simply do not function that way, if anything they make it worse because of the slip difference they allow before affecting any sort of positive influence. A mechanical LSD helps, but I can tell you it cannot and does not cure it. Addressing this issue with anything other than bushings or spring changes are simply a bandaid and do not address the root cause of he behavior.
Another note from my direct experience (something it seems a bunch of you lack and thus the ridiculous assertions in this thread) is that the stock carrier bushing (the liquid filled one) is prone to failure. I would even venture to say a large amount of Z owners have a failing bushing and don't know it. Every modified Z that is increasing grip levels (wider tires, better rubber, stiffr suspensions, aftermarket aggressive LSDs) is abusing this bushing and experiences negative performance they don't realize if they don't address it. As little as two launches at the strip has been shown to destroy the integrity. You can check yours by looking under the car the next time you arer so inclined: if the bushing has torn, you will see black streaks running down the subframe that holds the rear bushing and possibly on your exhaust pipe if you can see yours (spl's pics on their site show how theirs broke as well if you need a visual aid) or if the front-side of the rear bushing tore you can tell because the actual center metal portion of the bushing will not be centered and will be 'sagging'.
So why pay to have the same piece of **** bushing installed again? get a solid bushing. These bushings are integral to isolating suspension loads to be handled where they should be: the suspension.
/end
PS: support SPL as they are the one of the only companies (in the US no less) putting out the suspension parts we crave and that benefit the whole community. Their service is beyond amazing, their products are wonderful and their pricing is very reasonable for the amount of RnD they perform.
