Traction Control Off - Terrible Sound and Rear End Hopping
Hi!
It is a common misconception, solid diff and subframe bushings do not measurably alter the ride quality. Take for example your front suspension subframe, that is mounted solidly to the chassis without bushings. Your ride quality is mainly determined by your shocks/springs and tire. The purpose of the bushings on the rear subframe and diff are intended to isolate drivetrain noise. As mentioned, with solid diff bushings you will hear a slight gear whine from the diff, however since the subframe bushings are still retained, the noise increase is not too intrusive.
What are you talking about? Firstly, you absolutely want squat in a suspension. The squat is rearward transfer of the weight of the car and results in increased traction. why do you think ultra stiff race cars have such terrible 60ft times? it's a compromise between purposes but EVERY car for any purpose is made to have squat. from the race car that needs it to launch out of a corner to the drag car that needs it for launch.
Secondly, harder rubber can exacerbate the problem as the grip profile leads to loss of traction. You want grip not slip and I don't think the OP was wanting to spin at all.
Thirdly, solid differential bushings in NO WAY lead to a harsher ride. The only negative aspect is increased gear whine transmitted through the chassis. You get more consistent handling better lateral traction and force the suspension to act more positively. the car has soft bushings between the subframe and the frame that absorbs the harshness.
so your whole post was wrong, and leads members to the wrong conclusions. don't do that.
In a related note to a post someone made: a VLSD will not help your car on launch. They simply do not function that way, if anything they make it worse because of the slip difference they allow before affecting any sort of positive influence. A mechanical LSD helps, but I can tell you it cannot and does not cure it. Addressing this issue with anything other than bushings or spring changes are simply a bandaid and do not address the root cause of he behavior.
Another note from my direct experience (something it seems a bunch of you lack and thus the ridiculous assertions in this thread) is that the stock carrier bushing (the liquid filled one) is prone to failure. I would even venture to say a large amount of Z owners have a failing bushing and don't know it. Every modified Z that is increasing grip levels (wider tires, better rubber, stiffr suspensions, aftermarket aggressive LSDs) is abusing this bushing and experiences negative performance they don't realize if they don't address it. As little as two launches at the strip has been shown to destroy the integrity. You can check yours by looking under the car the next time you arer so inclined: if the bushing has torn, you will see black streaks running down the subframe that holds the rear bushing and possibly on your exhaust pipe if you can see yours (spl's pics on their site show how theirs broke as well if you need a visual aid) or if the front-side of the rear bushing tore you can tell because the actual center metal portion of the bushing will not be centered and will be 'sagging'.
So why pay to have the same piece of **** bushing installed again? get a solid bushing. These bushings are integral to isolating suspension loads to be handled where they should be: the suspension.
/end
PS: support SPL as they are the one of the only companies (in the US no less) putting out the suspension parts we crave and that benefit the whole community. Their service is beyond amazing, their products are wonderful and their pricing is very reasonable for the amount of RnD they perform.
/end
The hard tires are for burning up and smoking, so many posters tend to want to tear up tires doing donuts and such. If he really wants good traction, get some drag slicks. And if he doesn't want trouble from the law, he could find some tires rated for winter driving, ie snow tires. Their soft, heat them up once and they'll be sticky and still pass the boys in blues eyes.
As for the rougher ride, yeah not too much, but road noise is terrible. I've had two other car with independent rear ends, a Corvette and a Jaguar XKE. Although both mounted differently, replacing the bushings with solid mounts helped but made for a tad rougher ride.
All that said, I still like having a 306 hp (yes I know I know, that's just the factory-stated number) sports car and drifting around the corner coming out of my neighborhood every once in a while.
Thanks for all the responses guys. I was pretty sure it was wheel hop, if there was a secondary traction system stepping in and causing that kind of interference it would be retarded.
Last time I drove an IS 350 (has VDC and TCS) I took it to a parking lot that is like driving on ice when it's wet (super smooth asphalt) and tried to do ONE spin out with the TCS OFF button pressed. The car let me spin the car 180 and then the dash flashed the "traction" light, beeped and turned the system back on. Instantly stopping my slide as if I'd hit a wall. I assume this is what the Grand Touring 2007 models have on them, safety wise it's great in the rain and dicey conditions, but otherwise these systems are a b!tch when you just want to have some fun.
Haven't decided if I'm going to mod my HR, suspension or power. I spent a bunch of money on my WRX to get it to the point where it could beat an HR easily but that was definitely not the car for me. But if I do, suspension and wheels will be the first mods
Thanks again for the replies
Will the solid rear diff mounts also take car of the issue some of use have with the rear end ripping out, that would be from the stock bushings that alow movement so the soilds would restrain it more?
I don't really understand what you're saying. But I'd love to know the best improved bushings and mounts for improving rear end behavior. Any suggestions from you guys that wrote stories on here would be much appreciated.
Not to get in an internet fight, but I've built cars for many many years, I'm 50, I'll be 51 next month. Been building since I was 13. Squat is a rearward transfer of weight no doubt, but it's not good for traction and control. Thus we use ladder bars on a solid axel to gain the advantage of lifting the whole car and planting the lift weight on the rear. It also keeps the twisting action of the rear end to a minimum and allows for the front tires to still maintain traction and control. You squat, I'll lift.
Actually I do enjoy some wheel spin, reminds me of why I got rid of my AWD WRX. Certainly couldn't spin the rear tires when I felt like being a douche every once in a while in that car. Don't get me wrong though, I absolutely love this car and am taking every precaution to keep it in the best shape possible the entire time I have it. Got my clear bra, always drive the speed limit (or a few over - one speeding ticket in my previous car because cops hate Subaru's) and always stay up on maintenance.
stick to suspension.. having a nicely lowered car that handles on rails is so much more enjoyable and satisfying than power. you can get power in a sedan : )
I'm not taking any shortcuts with this car if I do mod it. Is it genuinely agreed that coil-overs of some sort are the best way to improve handling on Z's while lowering slightly as well?
I'm also thinking I'm going to end up buying the dual HR intakes, I love the sound of aftermarket intakes on these engines, and of course the few extra HP doesn't hurt either. :-D
1) set a goal - what will make you happy out of this car (power, handling, etc)
2) set a budget - what can you afford to spend (this will allow you to maximize your money to get the end result you want.)
3) set a framework of things you need, then identify the parts that meet your goals.
4) stick to your budget
absolutely coilovers make a difference... and the better they are, and the better you choose spring rates that match your application the better off you will be. the problem with just increasing your tire grip is that you then overload the suspension, causing even more body roll because the spring rates aren't equipped to handle the increased loads on them. hence going stiffer. it goes deeper but that is just a small example of the symbiotic nature of modding your car. take from one hand put into the other... more power? you need more grip... more grip you need better handling, etc. just like you can't put FI on your car without upgrading your clutch you can't upgrade one part of the suspension without another or you risk wasting your time.
biggest bang for your buck is going to be (in this order)
- coilovers (or simply lowering springs and sway bars if you don't have the cash)
- rims/tires (go quality, but make sure if you buy expensive tires you are willing to replace them... about once a year... the stickier they are, the more they wear)
- power or LSD (if you have a base, if not Vlsd works for a while)
- brakes, bodykit etc (whatever you are lacking.. if you are doing the flashy show car, the bodykit will drastically change the look of your car)
some notes:
this is what I would do. all together expect to spend 5-7k for the parts related to this list. or more. yes ,it is that expensive to mod your car.
you can look into buying used parts but I would not recommend it unless you are savvy in the platform. I made my share of **** purchases when I was a noob.
and price shopping is good, you don't want to overpay, but do not work the vendors to save 10 bucks... develop a relationship (local if you actually have them) as that will go much farther than 10 bucks here or there.. look at that in context of the total you want to spend. 10 bucks off of a 1400 coilover package is retarded to fiend over. that isn't even 10%.
Tom
^ what he said. Motormouth wins this one.
idk maybe I missed this one but.. does it wheel hop allll the time? it could be the ground level too.. I dont wheel hop ever.. but sometimes I do and it is the bad roads so I lay off the throttle
When you installed do you pop it out on the diff side or the the back or did it matter? How easy was it to put the aluminum bushing in? And if anyone knows what's the differnce between the 350zmotorsport and SPL version?
This hasn't gone away for me. It's incredibly annoying, I can't launch it in a straight line hard without either the wheels hopping uncontrollably or my clutch slipping going into second gear (guessing it's because I still haven't had the master cylinder recall taken care of). I really hope this problem changes when I have different tires once the stock RE050's are gone.
Just wanted to say this rear bushing is a great quality, knowing it will never bust is a plus. If yours hasn't busted yet it most likely will unless you don't push your car much. My car doesn't even have alot of miles but having more HP probably contributed to busting sooner. When I pulled mine it was a minor tear making the car almost unpredictable when shifting almost made me swirve into the car next to me at one time. Even though install takes a little time it's well worth the final outcome most likely never have to change that part ever.
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
