ECU Reset
Old Nov 2, 2008 | 06:10 PM
superz2004's Avatar
superz2004
Default ECU Reset
Does the manual way of resetting the ECU, as shown on several sites like technosquare's, reset the P1273 code or do i have to go to the dealership?
Old Nov 3, 2008 | 07:05 AM
str8dum1's Avatar
str8dum1
just saw your other post. take it to the dealer.
Old Nov 3, 2008 | 12:21 PM
OCG35's Avatar
OCG35
no.
I saw your other post too...
Resetting the ECU doesn’t do anything for your issue... it doesn’t clear codes either...
The O2 sensors have a heater element in them - and it sound like your has gone bad... coincidently, I have the exact same problem, same sensor location too... since it is the 2nd sensor - I'm leaving mine alone for now as it does not affect the A/F (as sensor 1 does)...
You can clear the code with Cipher or consult II, but it will probably just come back on... mine was cleared 3 times and it hasn’t come on again.
If it bothers you, take it to the dealer - or buy a new sensor ($188 from Riverside Infiniti - more from most other dealers) and have a local shop install or DIY.
There isn’t much more that can be said to help... you don’t need to open another thread about it.
Old Nov 3, 2008 | 12:47 PM
superz2004's Avatar
superz2004
I already changed out the sensor. Thats why it frustrates me that the CEl is still on after I manually resetted it.
Old Nov 3, 2008 | 01:55 PM
OCG35's Avatar
OCG35
how did you "manually reset" it?... if you are referring to resetting the ECU, I already told you that doesn’t clear codes.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
