Lifter noise?
Old Nov 3, 2008 | 12:10 PM
rmfible's Avatar
rmfible
Default Lifter noise?
I have had a lifter noise for some time now but finally got around to taking the valve covers of but nothing that i can see seems to be causing it. Anyone ever had any lifter problems. I have a 2004 350z with 117,000 miles. Are the lifters solid or hydraulic?
Old Nov 3, 2008 | 01:00 PM
06dieselZ's Avatar
06dieselZ
Is it a clicking sound from the engine?
Old Nov 3, 2008 | 01:56 PM
rmfible's Avatar
rmfible
yeah it is def coming from the valve train.
Old Nov 3, 2008 | 02:33 PM
j1234's Avatar
j1234
what oil filter are you using
Old Nov 3, 2008 | 07:58 PM
go-fast's Avatar
go-fast
follow service manual instructions for checking valve lash,you don't have lifters in a vq.the cams act directly on valve,different thickness buckets determine lash.
Old Nov 3, 2008 | 08:02 PM
350 Rookie's Avatar
350 Rookie
Those buckets are called lifters
to the op. get a feeler gauge and check the clearances. Refer to Service manual for specs
Old Nov 3, 2008 | 08:16 PM
go-fast's Avatar
go-fast
what do they lift?
Old Nov 3, 2008 | 08:55 PM
Motormouth's Avatar
Motormouth
they are not called lifters. they are called buckets. or bucket tappets I think.
lifters are different.
Old Nov 4, 2008 | 08:43 AM
06dieselZ's Avatar
06dieselZ
Hmm I have the same noise also but don't have knowledge or tools to fix this.
Would the dealer warranty this?
Sorry for the thread jack
Old Nov 4, 2008 | 09:02 AM
tecni's Avatar
tecni
you actually have to take out the cam and install a thicker bucket and check the clearance. The service manual will tell you what clearances you're supposed to have.
Its a PAIN in the @$$ to do.
Old Nov 4, 2008 | 11:41 AM
go-fast's Avatar
go-fast
you do have to pull cams to adjust,but not to check.you actually need cams in to check.you might only need to change a bucket or two,so check and do the math.to determine what you need compare to service chart.bucket # is underside of bucket so expect some down time unless shop you go to has spares saved up.
Old Nov 4, 2008 | 07:02 PM
tecni's Avatar
tecni
I know Jeremy from Performance Factory keeps plenty of them around.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
