APS Oil Pan Drain Plug Torque Spec
Old Nov 20, 2008 | 04:05 PM
G35cTT's Avatar
G35cTT
Originally Posted by rcdash
+1 to fumoto. Do you actually collect metal shavings on the magnet? If the oil filter isn't catching them, I'd be surprised...
What size Fumoto valve do you use on the APS oil pan??? Just curious because it doesn't look like the same size as the oem
Old Nov 20, 2008 | 04:45 PM
coachk's Avatar
coachk
I used the 18mm x 1.5 Fumoto on my APS pan. The APS plug is 14mm
Old Nov 20, 2008 | 06:34 PM
G35cTT's Avatar
G35cTT
OK so you used the F-104, how come you didn't go for the F-106 14mm-1.5? Also wanted to ask it doesn't stick out too low? I was scared it might hit on a speed bump? Thanks for the info
Old Nov 20, 2008 | 07:06 PM
Abishop's Avatar
Abishop
i used thread sealant last time on mine, works great.
Old Nov 20, 2008 | 07:37 PM
blackfairlady's Avatar
blackfairlady
He probably stripped the original 14x1.5 and had to drill and re-tap to a bigger size.
Old Nov 21, 2008 | 07:42 AM
coachk's Avatar
coachk
Exactly.....I'll find a pic and post it
Old Nov 21, 2008 | 01:57 PM
coachk's Avatar
coachk
^^^^ my car is stock height btw ^^^^^
Old Dec 8, 2008 | 08:17 PM
blackfairlady
Though I'm installing a Fumoto, I may as well update the thread.
I read on here that APS recommends a torque of only 8 ft. lbs. for the drain plug. I have not personally verified this with APS, but just in case anyone is looking.
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
