Transmission
Old Nov 11, 2008 | 08:30 AM
RedZOH3's Avatar
RedZOH3
Default Transmission
Ok, heres the deal. I have been searching on here for someone with the same issue and I cant seem to find the subject I am looking for. The issue with mine is when I shift from 2nd to 3rd. If I dont pause between gears I wind up grinding the gear. I thought I saw a thread on here about this but I cant find it. Is this a common problem? Mine is a '03 Touring, manual tranny obviously.
Old Nov 11, 2008 | 10:56 AM
jray8's Avatar
jray8
https://my350z.com/forum/search.php?searchid=7518225
Old Nov 11, 2008 | 11:17 AM
Ejekt's Avatar
Ejekt
It happens to my car too, usually when the tranny is cold. In a nutshell, its most likely a bad syncro that needs to be replaced.
Old Nov 11, 2008 | 11:22 AM
Welcome.
Wrong forum.
Common question.
Old Nov 11, 2008 | 03:56 PM
Spike100's Avatar
Spike100
Hello and welcome.
The transmission problem you describe is well-documented. You can read a lot about this by searching this sub-forum.
The fix is replacing the transmission (probably not what you want to hear).
--Spike
Old Nov 12, 2008 | 04:20 AM
RedZOH3's Avatar
RedZOH3
So its a problem with the synchronizer. My options are replace the tranny for 3500, live with slow-shifting 3rd, or spending 2500 to fix MY tranny? I will take slow shifting till my tranny completely gives out for 100 Alex.
Old Nov 12, 2008 | 06:54 AM
Jgrizzle's Avatar
Jgrizzle
Wait till it starts doing it in 5th.... then it gets REAL fun.
Old Nov 12, 2008 | 10:42 AM
Ricfutures's Avatar
Ricfutures
"Fixing" the tranny will not help. The only real fix is a complete swap. Best advice is to keep an eye out for a used CD009 (latest Revision) and jump on one when you find a good deal. I got mine with installation for $750.
The drive train classifieds are the best place to start.
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
