What else can we do to stick NA?
Old Aug 18, 2003 | 11:27 AM
nonmature's Avatar
nonmature
ya why no internal modification a bump in the compression would make a good hp hop... and wouldnt you consider cams internals anyways??? why not forged pistons with a compression bump and connecting rods
-non
Old Aug 18, 2003 | 11:39 AM
KONVERTER's Avatar
KONVERTER
tranny?
Old Aug 18, 2003 | 11:42 AM
Enron Exec's Avatar
Enron Exec
Anyone interested in a group buy on the CF hatch or the pair of doors? Not that i could afford those things even at 50% off ... 8-P
Old Aug 18, 2003 | 11:46 AM
KONVERTER's Avatar
KONVERTER
only thing i see the CF doors good for is if you put a lambo kit on them...
Old Aug 18, 2003 | 11:47 AM
Juztin's Avatar
Juztin
I'd be good if everything costed 1/3rd of what it's at list. I realize it's pure CF which is awsome, but dang that's stuff is expensive. I wonder how much it costs them CF wise in material.
Old Aug 18, 2003 | 11:48 AM
Juztin's Avatar
Juztin
Advance the timing by +2 (static) is another.
Old Aug 18, 2003 | 12:35 PM
Enron Exec's Avatar
Enron Exec
Since the door and hatch dont support any other part of the car except themselves, im thinking about fiberglass. It weights about as much as CF but is alot cheaper. But then again, there needs to be something to hold up all that glass too.
Ohhh wait, anyone think a fiberglass and lexan door/hatch will be available? lol. One draw back is the lexan is gonna get scratched sooner or later.
Old Aug 19, 2003 | 07:54 AM
MY350Z.COM's Avatar
-non
ahhh true
Old Aug 19, 2003 | 09:56 AM
Topics II's Avatar
Topics II
-non
espirit makes 11.5:1 pistons that are the same bore as stock. They sell for like $2500 or so...
Old Aug 19, 2003 | 10:01 AM
nonmature's Avatar
nonmature
Originally posted by Mike Wazowski
ahhh true
just sayin you know there will be some serious NA kids here that will go all out here is the serious NA beast... intake, plenum, headers, test pipes, cat back, clutch, lightened flywheel, pullies, grounding kit, cams, rods, 11.5 compression pistons, sleeved block, and a new head gasket..... and a 150 shot....hehehe (yes I realize nitrous is not NA) but that should be a very "quick" car with or without nitrous...
-non
Old Aug 19, 2003 | 10:19 AM
MY350Z.COM's Avatar
nah, no happy juice for me.
can you explain sleeves to me. what are they?
Old Aug 19, 2003 | 10:24 AM
little_rod's Avatar
little_rod
SGP racing has some 11.5:1 forged pistons for like half that, $1320.
Old Aug 19, 2003 | 10:41 AM
nonmature's Avatar
nonmature
honestly you wont need them unless you were gonna go with that nitrous shot or something real crazy... block sleeves will "sleeve" the cylinders walls with iron(i think its iron) it makes it much tougher under high pressures... I think eagle had a set of sleeve that they ran 50-60 psi tests on and passed with flyin colors anyways I think thats correct, feel free to correct any of it...
-non
oh ya I forgot valves, valve srings and retainers above
Old Aug 19, 2003 | 03:57 PM
menehune's Avatar
menehune
How about increasing the intake valve sizes? or maybe back cutting the valves to improve the flow.
How about race-balancing the engine?
Fuel "cool can".
For automatics, a high-stall torque converter, rear-end gearing, valve-body upgrade, shift kit upgrade, tranny cooler, trans-brake(locks the tranny in first and reverse for "clutch-like" releases, not sure if there is for any import but would be nice).
Old Aug 19, 2003 | 04:32 PM
MATIX's Avatar
MATIX
We carry the Esprit pistons if anyone's interested.
3vilbunny
Jul 18, 2017 05:10 PM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
Paul.
Oct 16, 2015 07:34 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
350Shadow
Sep 22, 2015 08:30 AM
