where to run wires for innovate lc-1 and gauge?
Ok got my o2 gung welded on exhaust today and now trying to figure out how to wire my innovate lc-1 to my gauge. Not sure where i can get into the cabin thru the firewall at. My gague is in the a pillar. How do some of you run ur wires or any suggestions on what i can do.
+1....i ran mine thru the shifter gromet in the center console. once you plug the lc1 into the o2 sensor just run the wires under the car and use zipties to keep em tight, and just run the wires thru shifter..and bundle up the extra under the a/c *****. then i just have the wires where you plug in to monitor from laptop or whatever run between the console and carpet on the passenger side and they sit under the passenger floor mat.
its the easiest and least messy way. if you were nearby, id help you install it. if ya need anything, just post...gladly will help ya out.
Dan
Dan
I ran it from the test pipe into the cabin thru the shifter and then plugged it into the lc-1 and stashed that under the ac unit and ran the wire upto the a pillar. Worked perfectly. Thx for the advicd
in the rain cuz it might not seal correctly with wires between it and may leave cracks for water to seep through.i learned the hard way
Dan
350Z_Al
Oct 29, 2020 07:44 PM
