how to disable immobilizer for good?
Old Nov 16, 2008 | 06:16 PM
mike.y's Avatar
mike.y
Default how to disable immobilizer for good?
Hey does anyone know how to disable the factory immobilizer?
any help would be greatly appreciated.. or maybe i can get ecu or bcm module sent out to get it removed? or what would i need to hack...
Old Nov 16, 2008 | 06:21 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
im not sure if its removeable i suppose you could put a key next to the NATS antenna constatanly and then figure out how to do a start button.
Old Nov 16, 2008 | 06:27 PM
mike.y's Avatar
mike.y
i am trying to determine how to fully remove it... i have a busted bcm as well as a slew of other issues. I would like to know how other folks are doing it...
Old Nov 16, 2008 | 06:28 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
stand alone and a buch of re wiring what happend to yoru BCM
Old Nov 16, 2008 | 06:44 PM
mike.y's Avatar
mike.y
bcm got fried in a freak accident...
car still starts but lost window and door lock control...
going to pick up another bcm but i am also setting up remote start which would involve me buying another adapter.. and since my roommate lost my only other key
i am pretty much
buying another bcm, getting 2 new keys, getting them to reset the bcm to my new specs as well as buying the module... wonder if there is any way that we can just bypass it all by taking out specific pins
Old Nov 16, 2008 | 06:45 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
well you have to program teh bcm on these cars.
Old Nov 16, 2008 | 06:59 PM
mike.y's Avatar
mike.y
so no dice huh i am boned out of like 500 dollars then?
anyone know btw how much a bcm is?
Old Nov 16, 2008 | 07:08 PM
mike.y's Avatar
mike.y
i just had a thought in regards to this...
it shows in the wiring diagram that red/blk is ignition as well as key sense. if i sent a 12 v switched power to it w/o the proper key i believe that it would turn on the ignition correct?
Old Nov 16, 2008 | 07:26 PM
SirSpeedyZ's Avatar
SirSpeedyZ
steal a Z did we?
Old Nov 16, 2008 | 07:32 PM
mike.y's Avatar
mike.y
nope just had a stream of bad incidents occure one after another..
1 have 1 good key
1 bad bcm
Old Jul 20, 2013 | 04:55 PM
mrathell's Avatar
mrathell
Expand on this please. Walk me through the modification please.
Old Jul 20, 2013 | 05:15 PM
Rcracertwo's Avatar
Rcracertwo
Can wont run if u do this
Old Jul 20, 2013 | 05:26 PM
KingBaby's Avatar
KingBaby
Hardest Setting
I'm under the impression UpRev always you to turn this off...
Jambo016
Sep 16, 2016 01:08 PM
