Any real gains from using a higher octane fuel?
Old Aug 20, 2003 | 05:44 AM
cbsuper's Avatar
cbsuper
Default Any real gains from using a higher octane fuel?
In AZ we are having quite a fuel bind and prices are becoming outrageous for gas. For the 91 octane fuel I've seen prices as high as $2.90 a gallon and read some places are charging as much as $4.00 a gallon. While I know that $4.00 a gallon sounds more like the gas shop is trying to gouge its consumers, $2.90 is still too much for premium gas. So I switched to the 87 octane fuel for the time being and have not noticed any difference in driving on this fuel and 91 octane fuel. Hell, I don't even notice a difference between this fuel and 103 octane fuel. So I'm just wondering do you guys really notice a difference in power by using a higher octane fuel? I'm not saying that I will permanently switch to 87 octane, but dang if it isn't cheap and I still get the same performance!
Old Aug 20, 2003 | 06:01 AM
Zaphod 350z's Avatar
Zaphod 350z
I certainly do. I've never put anything under 94 in my car, but the days that I'm running a fuel additive the car seems to pounce when i tap the pedal.
Those are some pretty bad gas prices. Might I suggest toluene? Sherwin Williams paint stores sell it for $5.50 a gallon. It is pure 117 octane. 20 gallons of 91 at your price is $58. Assuming $2.00 for 87 (which i think is high): $2 x 17 = $34 + $16.50 (3 gallons of toluene) = $50.50 and you're probably looking at around 92 - 93 octane with that mixture.
Old Aug 20, 2003 | 06:38 AM
peptidbond's Avatar
peptidbond
Please tell me you are joking about the Toluene! Toluene may be equal to 117 when evaluated for octane rating, but it is certainly not safe for an unmodified engine. First, the octane rating only measures the propensity to knock (or detonate) as compared to pure octane. A chicken might have a octane rating of 12000 because they tend not to detonate, but that does not mean you want to place it in your gas tank. Another more relevant example might be methanol. Methanol has a very high octane rating and can be used in an engine. However, the engine must be prepped for its use. You can't just go and put pure methanol in any old engine. Furthermore, Toluene is a cyclic hydrocarbon (hence the octane rating). While some components of gas are cyclic, the vast majority are not. Oxidation (burning) of cyclic hydrocarbons is much less efficient than chain hydrocarbons. Hence, cyclic compounds such as benzine and toluene tend to soot instead of burning cleanly. If they do not fully oxidize, then you will not get the same power. In addition, the soot created will cause your spark plugs to foul.
As for the gas prices in Phoenix, it is because a gas pipeline from Tucson (sp?) to Phoenix has ruptured. It has now been repaired and they are going to test it this morning. Gas prices and availability should return to normal in the next day or two.
As for using 87 as opposed to 93, this can be done, although I would not recommend it. Remember, the numbers are a meassurement of the propensity to detonate. There is little difference between 87 and 93. They both will generate the same ammount of power. However, 87 will begin to detonate at a lower temperature and pressure. Hence, the Z will notice the 87 octane and retard its timing and fuel curve. This is where you will lose power. The Z will become more conservative if it notices knock. The gas itself will produce the same power, the car will not.
Old Aug 20, 2003 | 06:56 AM
cbsuper's Avatar
cbsuper
Originally posted by peptidbond
[B]As for the gas prices in Phoenix, it is because a gas pipeline from Tucson (sp?) to Phoenix has ruptured. It has now been repaired and they are going to test it this morning. Gas prices and availability should return to normal in the next day or two.
Actually, they are proposing that the testing can take up to a week, but hopefully gas prices will still come down in anticipation of the gas line being repaired and running.
Old Aug 20, 2003 | 07:19 AM
Zaphod 350z
Default Everything you ever wanted to know about Toluene...
Read and enjoy...
Toulene
R+M/2...114
Cost...$2.50/gal
Mixtures with 92 Octane Premium
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
Rocket fuel FAQ
Copyright ã 1999,2000 by Eliot Lim This paper may be freely distributed, provided it is distributed in its entirety
Last revised by Eliot Lim: February 8, 2000
Last augmented by Charles Smith: January 6, 2003
Background
In late 1997 I became the lucky owner of 1 out of 150 1998 Porsche 993 Targas, the very last of the air cooled classics. As I drove it through the winter of 1997 and into the spring of 1998 I noticed that the engine lost some of its sweetness. Since this behavior was strongly related to ambient and engine temperature I suspected that the engine electronics were retarding its ignition timing due to insufficient fuel octane.
I started experimenting with octane boosting by first adding small doses of over the counter octane boosters and noticed immediate improvement. The engine ran smoother and quieter, was more willing to rev and had noticeably sharper throttle response. The octane shortage was confirmed by the sticker on the filler cap that stated that 93 octane fuel was needed. Since the highest octane rated fuel that was commonly available in Washington state is 92, I decided to investigate long term cost effective octane boosting so that I could fully enjoy the performance that this car offered.
My other car at the time, a 1990 Audi V8 quattro had an even more dramatic response to octane boosting. I managed to convince a few good friends to try it and the reaction was overwhelmingly positive. When I attempted a broader based dissemination of this exciting find, I was greeted largely by broad unyielding skepticism and plenty of FUD (fear, uncertainty, doubt) regarding toxicity, safety and engine damage. There arose a need to more clearly explain the details of octane boosting, hence giving rise to this article.
Q: Will my car benefit from octane boosting?
A: Consumer organizations have effectively emphasized the larger markups that oil companies charge for high octane gasoline, implying that for most vehicles higher octane fuel is a complete waste of money. It has been quite a long time since the consumer alert was issued. Since then engine technology has evolved greatly, while people's perceptions generally have not.
Modern vehicles now use computerized engine management systems that can react to engine knock and retard ignition timing if low octane fuel is being used. Consequently cars are now being manufactured with very high compression ratios that appear to give good fuel economy and at the same time good performance. This combination does assume that fuel of adequate octane is being used.
Q: Why bother to boost octane at all since my engine can run just fine on lower octane fuel?
A: For a high compression engine to run on low octane fuel, the engine management system will need to retard the ignition timing to prevent preignition or pinging. Retarding the ignition timing means that the firing of the spark plug is delayed until a later moment in the compression stroke. It does not take much to see that a later onset of combustion means that the combustion is less complete, which in turn mean less power and poorer fuel economy. It is possible that the casual driver will still come out ahead in terms of saving money by using low octane fuel, but the retarded ignition advance also means a rougher running engine and a much duller throttle response. Thus octane boosting is not necessarily of interest to all motorists but rather the enthusiasts.
For turbocharged or supercharged engines, insufficient octane will also lead the engine management system to curtail the amount of boost which in turn defeats the purpose of these engines.
Q: How did you discover using toluene?
A: Someone came across a web page that described various DIY home brew octane booster formulas. One of which used toluene as its main ingredient. As a Formula 1 racing fan of many years, I recalled that toluene was used extensively in the turbo era in the 1980s by all the Formula 1 teams. The 1.5 liter turbocharged engines ran as much as 5 bars of boost (73 psi) in qualifying and 4 bars (59 psi) in the actual race. Power output exceeded 1500bhp, which translates into 1000bhp/liter, an astronomical figure.
A motorsports journalist, Ian Bamsey, was able to obtain Honda's cooperation for his book "McLaren Honda Turbo, a Technical Appraisal". The book documents the key role that the toluene fuel played in allowing these tiny engines to run so much turbo boost without detonation. The term "rocket fuel" originated from the Formula 1 fraternity as an affectionate nickname to describe its devastating potency. Thus I concluded that I should focus my research on using toluene for my octane boosting project.
Individuals with good long term memory will recall that when unleaded gasoline was first introduced, only low octane grades were available. While it is not entirely clear that high octane super unleaded gas came about as a result of the advances in fuel technology in Formula 1, there is every reason to suspect that this is indeed the case, since many of the major oil companies were involved in the escalating race to develop increasingly potent racing fuel during this era.
Q: Why do you think toluene is better than other types of octane boosters?
A: Several reasons:
Mindful of the evil reputation of octane boosters in general, toluene is a very safe choice because it is one of the main octane boosters used by oil companies in producing ordinary gasoline of all grades. Thus if toluene is indeed harmful to your engine as feared, your engine would have disintegrated long, long ago since ordinary pump gasoline can contain as much as 50% aromatic hydrocarbons.
Toluene is a pure hydrocarbon (C7H8). i.e. it contains only hydrogen and carbon atoms. It belongs to a particular category of hydrocarbons called aromatic hydrocarbons. Complete combustion of toluene yields CO2 and H2O. This fact ensures that the entire emission control system such as the catalyst and oxygen sensor of your car is unaffected. There are no metallic compounds (lead, magnesium etc), no nitro compounds and no oxygen atoms in toluene. It is made up of exactly the same ingredients as ordinary gasoline. In fact it is one of the main ingredients of gasoline.
Toluene has a RON octane rating of 121 and a MON rating of 107, leading to a (R+M)/2 rating of 114. (R+M)/2 is how ordinary fuels are rated in the US. Note that toluene has a sensitivity rating of 121-107=14. This compares favorably with alcohols which have sensitivities in the 20-30 range. The more sensitive a fuel is the more its performance degrades under load. Toluene's low sensitivity means that it is an excellent fuel for a heavily loaded engine.
Toluene is denser than ordinary gasoline (0.87 g/mL vs. 0.72-0.74) and contains more energy per unit volume. Thus combustion of toluene leads to more energy being liberated and thus more power generated. This is in contrast to oxygenated octane boosters like ethanol or MTBE which contain less energy per unit volume compared to gasoline. The higher heating value of toluene also means that the exhaust gases contain more kinetic energy, which in turn means that there is more energy to drive turbocharger vanes. In practical terms this is experienced as a faster onset of turbo boost.
Chevron's published composition of 100 octane aviation fuel shows that toluene comprises up to 14% alone and is the predominant aromatic hydrocarbon. Unfortunately composition specifications for automotive gasoline is harder to pin down due to constantly changing requirements.
Chevron's web site also describes the problems of ethanol being used in gasoline.
MTBE was heavily touted as a clean additive several years ago, and became a key ingredient in reformulated gasoline that is sold in California. But recently new studies arose that showed that MTBE was far more toxic than previously imagined. Organizations such as oxybusters have formed around the country to eliminate the use of MTBE in gasoline and several states, including California have passed new laws to eventually outlaw MTBE.
Old Aug 20, 2003 | 07:20 AM
Zaphod 350z
Default Toluene FAQ Part II
Q: How much toluene should I use per tank of gas?
A: Octane ratings can be very easily calculated by simple averaging. For example, the tank of an Audi A4 1.8TQ is 15.6 gallons. Filling it with 14.6 gallons of 92 octane and 1 gallon of toluene (114 octane) will yield a fuel mix of:
(14.6 * 92) + (1 * 114) / 15.6 = 93.4
The Audi A4 1.8T is a good example of a car that has very high octane needs if it has been modified to produce more turbo boost. The base compression ratio of this car is a very high 9.5:1 and when an additional 1 bar (14.7 psi) of turbo boost is applied on top of it, the resulting effective compression ratio is way beyond what 92 or 93 octane fuel can ever hope to cope with. Most modified 1.8Ts running without octane enhancement are running with severely retarded ignition timing and boost.
Q: Will toluene damage my engine or other parts of my car?
A: A 5 or 10% increase in the aromatic content of gas will most likely be well within the refining specifications of gasoline defined by ASTM D4814, which specify an aromatic content of between 20% and 45%. What this means is that if the 92 octane gas that you started off with had an aromatic content of say 30% and you increased it by 10% to 40% you would still be left with a mix that meets the industry definition of gasoline. So the above question would amount to: "Will gasoline damage my engine or other parts of my car?"
Even in the unlikely event that the 92 octane gas has a aromatic content of 45% the resulting mix would still be within the bounds of gasoline sold in other countries.
Q: Isn't toluene an extremely toxic substance?
A: The common perception of toluene's toxicity far exceeds reality. Fortunately there is an ample body of information available that specifically addresses this question. Toluene is more toxic than gasoline but it is certainly not agent orange or cyanide. See the Agency for Toxic Substances link below in the reference section.
US Environmental Protection Agency Chemical Summary
US Agency for Toxic Substances and Disease Registry (ATSDR)
National priority list of toxic substances
Note that the ATSDR also rates gasoline as a hazardous substance.
Mobil's spec sheet for toluene even goes as far as saying that "Based on available toxicological information, it has been determined that this product poses no significant health risk when used and handled properly."
Q: Isn't toluene an active ingredient of TNT (trinitrotoluene) and is thus deadly?
A: In the same way that cotton wool is the base ingredient of nitrocellulose (guncotton) which in turn is the main ingredient in modern smokeless gunpowder. Using this reasoning one could conclude that cotton wool is a deadly substance. This question reflects a poor understanding of basic chemistry but unfortunately it has been asked often enough.
You don't know for sure if you are really getting what is being advertised. You should find out if the fuel inspectors verify the actual octane of the racing gasoline in addition to ordinary gasoline. If you paid $3/gallon and only got 94 or 95 octane instead of 100 octane you may conclude erroneously that your car does not benefit from octane boosting.
You don't know what octane boosters are used in the racing gasoline. The worst case scenario is buying leaded racing gasoline without knowing it. Unleaded racing gasoline may still contain damaging octane boosters like MMT or methanol. A very high alcohol content will lead to fuel line erosion, accelerated fuel pump wear, very poor fuel economy and possibly lower performance, as alcohols have a less impressive MON rating than aromatics.
It takes smaller quantities of toluene to achieve the same octane boost compared to 100 octane racing gas. I have not seen unleaded racing gas for sale that exceeds the octane rating of toluene.
Since toluene is not officially sold as a fuel, gas taxes do not apply. Also racing gasoline tend to have higher markups being of interest to the performance minded enthusiast and thus is very likely to be more expensive to buy and use long term than toluene, which is typically used in more mundane applications like paint thinner.
Q: Ok, what is the catch?
A: It should be mentioned that in the US, efforts are underway to reduce the aromatic content of gasolines in general as a higher aromatic content leads to higher benzene emissions. Benzene is an extremely toxic substance. However it should also be noted that the proportions that is being discussed in this FAQ is relatively small and in the grand scheme of things is probably insignificant. Moreover, the industrial standard for defining gasoline composition allows plenty of leeway in aromatic content and the proportions present in US gas is already lower than most other countries. I therefore feel that the information provided here is useful to a performance minded car enthusiast while not being significantly detrimental to the environment.
Old Aug 20, 2003 | 07:28 AM
little_rod's Avatar
little_rod
Well, I understand your concerns with toluene and xylene. BTW, toluene has an octane rating of 114 and xylene has an octane rating of 117. They are both in every tank of gas you get. Both of these are also main ingredients in any off the shelf octane booster. Now having too much can mess up your seals and such, but used in moderation, they should be fine. Here are a couple of sites that talk about it:
http://www.gnttype.org/techarea/misc...explained.html
http://www.elektro.com/~audi/audi/toluene/
Old Aug 20, 2003 | 07:29 AM
j's350z's Avatar
j's350z
Toluene like stated above is perfectly safe for your car. I started a thread about it a couple of months ago when I started using it. Thats what I'll be using with my second map of my SMT6. The local sherwin williams stocks up on it over the summer since so many people use it for racing...
Old Aug 20, 2003 | 07:39 AM
little_rod's Avatar
little_rod
Well, I have used it also, and I will say, I have noticed a slight decrease in mpg if you look closely while using it. But you will also notice how much better your engine runs. At high rpms, this booster makes your car run ALOT smoother. Maybe I get the decrease cause I rev it more, lol. But the smoothness and ease of revving at high rpms is very noticeable.
As for lower than 91 octane, you will probably get a few HP less than you could otherwise. Just so it is short-term, I don't see any problem with it.
Old Aug 20, 2003 | 09:27 AM
peptidbond's Avatar
peptidbond
Zaphod 350z,
GOOD information! You are right, Toluene used in moderation is a good thing. My point was that you would not want to run it 100%. I did not want the first poster to get the impression that he could switch from Mobile to Sherwin Williams. Thanks much for the info. I might actually try this. I still think that Toluene would soot too much for a gas car, but it is worth a shot. Benzine by the way is not appropriate at all. In almost every circumstance, benzime will soot during combustion. If you want an example, pick up one of those flexible fast food spoons (the ones that bend, not break). Then, simply light it on fire. All those little soot specks you will see would be really bad for plugs.
Old Aug 20, 2003 | 09:53 AM
peptidbond's Avatar
peptidbond
I just re-read the article above. Very interesting to say the least. In fact, it made me think about my assumption on toluenes shape. However, after a quick search, I confirmed that I was correct the first time. Toluene is a cyclic hydrocarbon. For those that are interested, here is a picture of benzene and toluene (finally remembered how to spell benzene too):
Benzene
Toluene
Old Aug 20, 2003 | 10:46 AM
Zaphod 350z
Definitely not the message I wanted to convey! I should have made the part about mixing 17 gallons of gas with 3 gallons of toluene clearer.
I'm running catless, as well as irridium plugs ikh22, so the sooting is less of a problem and the benzene biproduct is only a conern for the cats and squirrels that might be haning out behind my car when i start it.
As far as performance, I have not done good data logs with this car because the standard OBDII software isn't comprehensive enough. However when I ran it in my S4 I was able to graph the changes. There was definitely a performance difference. Advanced timing, increased boost, lower EGT's. Of course the car had an ecu with dynamic value mapping so that helped as well. On the Z it will still help, and especially with my running nitrous oxide.
Old Aug 20, 2003 | 11:27 AM
SoCalKid86's Avatar
SoCalKid86
feels like I'm back in chemistry class all over again...
Old Aug 20, 2003 | 07:09 PM
raceboy's Avatar
raceboy
Uhhh, huhhh. Forget the chemistry, unless you are experiencing detonation, higher octane fuel will LOWER your HP so you are wasting your time and money. Higher octane fuel has a slower burn rate and that is why it resists detonation, but it also will not make as much HP unless you are actually knocking and the car's ECU is pulling back the timing. Road and track actually did and article on this a year ago with an M3 and proved that the car made the highest HP with the recommended fuel rating and lost HP as the octane went up.
Impressive chemistry above, but ultimately a waste.
Old Aug 20, 2003 | 08:41 PM
little_rod's Avatar
little_rod
Well, raceboy, Sportscarmaganize did a test with the same Z. They dynoed the car with 91 octane and 100 octane. They got 5 more HP with the 100 octane gas. I know what you are saying though, it is harder for the engine to use the higher octane gas.
But you also have to see that every tank of gas probably doesn't meet the posted octane on the gas pump. So a booster might be getting it just up to par. It does depend on the engine and what it is built for, and that is true for most engines out there. Some engines that are built for lower octanes don't run as well on premium gas.
It is interesting though, cause although my engine seemed to run smoother and better with xylene, my mpg seemed to go down with it.
Old Aug 21, 2003 | 08:13 AM
cbsuper's Avatar
cbsuper
Zaphod 350z,
I'm not that big of an idiot to switch from regular gas to just toulene.
