sqeaking noise when ac is on...
Old Nov 25, 2008 | 05:14 AM
350ziggy's Avatar
350ziggy
Default sqeaking noise when ac is on...
Every morning I start the car and turn the ac to heat the cabin, Theres a squeaking noise thats noticable only from the front of the car. At first it was only heard from the front passenger tire. But now it can be heard from the front nose as well.
Any idea what it could be? Is it an easy fix, like a bolt that just needs tighting? Should I worry about it or is it normal with all nissans.
Its my first nissan and its an 06 with 23k on it. auto trans. if that would help.
Thanks again in advanced
ziggy
Old Nov 25, 2008 | 06:55 AM
SweetDreamZ's Avatar
SweetDreamZ
sounnds like your belt is loose...and the A/C compressor is adding enough drag to the belt to cause it to slip...thus squeal. Tighten your belt and you'll probably be fine.
Old Nov 25, 2008 | 08:38 PM
350ziggy's Avatar
350ziggy
Thanks SweetDreamZ! Hope thats the cure for this annoying mess. I will double check all bolts. Do you happen to know which exact bolt it happens to be? Dont mean to be a pest, but just want to make sure I got it right. Its my first import car.
Also, what do you think made it happen? Do you think its from driving it hard?
Thanks again for the help!
Old Nov 25, 2008 | 09:07 PM
Motormouth's Avatar
Motormouth
it could be a squirrel. no lie.
my 5th grade teacher had a squirrel living in his engine bay. one day when he pulled in (I was a crossing guard), A SQUIRREL jumped out of his ****ing car as he pulled in to the parking lot.
do you park near trees at all? it could be a moose as well. a very small moose.
Old Nov 25, 2008 | 09:09 PM
surfcity40's Avatar
surfcity40
belt or fan issue. can't be anything other than that.
Old Nov 25, 2008 | 09:10 PM
Motormouth's Avatar
Motormouth
except a squirrel or a moose (a really tiny one).
don't listen to these jokers... no one has ever heard of a belt making noise. it isn't alive is it? OH dear lord... IS IT?!
Old Nov 25, 2008 | 09:25 PM
surfcity40's Avatar
surfcity40
Don't listen to him. It IS NOT a cartoon issue.
Old Nov 26, 2008 | 05:35 AM
SweetDreamZ
I'm not implying that a bolt is loose....moreso that the BELT is loose. There is a tensioner pulley that is on the bottom side of the belt area...kinda more towards the passenger side of the car (if i remember correctly). You just have to loosen the bolt that locks that pulley into place...then turn the adjusting screw for that pulley, then lock that pulley back into place with it's bolt. This is assuming you have a DE motor, not the HR. I have no clue about the HR motor.
If you can't figure it out, you might want to just take it to a shop and have them tighten it. I can't imagine that it would cost THAT much.
Old Nov 26, 2008 | 05:42 AM
350ziggy's Avatar
350ziggy
Thanks guys! Appreciate all the feedback. SweetDreamZ, Thanks, I will check on it as soon as the rain lets up.
Surfcity40, Thanks I dont listen to kids nosense anyways, But I hope that its only the belt/fan issue. Its a beatiful car and just hate to hear it when its backing out of my driveway. Sounds like a bucket.
MotorMouth, Thanks for the heads up! I found a squirrel and shot him with my .45 and peeled his skin and bbq'd him for lunch, But the noise is still there, so it must be the belt like the gentlemen were saying!
Thanks anyways!
Old Nov 26, 2008 | 07:11 AM
Motormouth's Avatar
Motormouth
at least you got a delicious, free lunch out of it.
and yes, it's belt squeak most likely. when the temp changes (if it does in your part of californicaland) this sort of thing happens. the tensioner is super easy to adjust.
Old Nov 26, 2008 | 08:04 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
True tho, i heard some people found death mouse inside of intake pipe.
-JLee
Old Nov 26, 2008 | 08:07 AM
VO...'s Avatar
VO...
Administrator
+1
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
