Car turns off when starting.
Old Dec 3, 2008 | 01:45 AM
kihun's Avatar
kihun
Default Car turns off when starting.
When my car is warmed up and turn ignition on, it will turn off slowly with weak idle. But when my car is cold and turn it on, it won't turn off. if I give it a gas a little before it turns off, it stays on.. What's wrong with my car.. This happened after I got my transmission fixed.
Old Dec 8, 2008 | 12:53 AM
kihun's Avatar
kihun
bump bump bump!!!!!!!!!
Old Dec 8, 2008 | 08:25 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
check if you have no vacuum leaks, simply disconnect battery and reconnect it. Also try simply reset ECU.
Old Dec 8, 2008 | 10:51 AM
wannabuy350z's Avatar
wannabuy350z
there are no vacuum lines near the tranny. I say if you havent bumped up your idle. do so, idling at like 680rpms is retarded. take it to the dealer, and have them set it at 850
Old Dec 8, 2008 | 11:17 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ but OP's trouble sounds like vacuum leaks or ECU set.
Old Dec 9, 2008 | 07:31 PM
kihun's Avatar
kihun
I'll give it a try. I'll reset ECU by disconnecting battery.
Old Dec 9, 2008 | 07:58 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Before disconnect battery, try this first. Pretty simple but it has to be in perfect time tho.
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications
bcoffee20
Nov 19, 2015 06:39 PM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Daniel_dh
Sep 7, 2015 12:56 PM
