Engine Noise
Old Jan 19, 2009 | 10:34 AM
carlos305's Avatar
carlos305
Default Engine Noise
Ok so i woke up sunday morning to go to work, i let my car warm up for about 10-15 mins then i get on highway which was completely empty at 9:00am so i got tempted to gun it , so i floored the car and when i let off after second gear i heard a loud rattling noise like if a piece of metal was loose inside the engine or tranny, what can this be? it only makes that noise after i release the load of the engine.
Old Jan 19, 2009 | 11:26 AM
carlos305's Avatar
carlos305
any ideas?
Old Jan 19, 2009 | 11:31 AM
lowtempo's Avatar
lowtempo
you should jack the car up and crawl under and see if anything is loose. That is what the mechanics would do and charge you an arm an a leg. Shake, wiggle and tap anything that can make noise. There might be something loose rolling around down there.
I had a rattle that would happen everytime I excelerate that drive me crazy and I found it to be the parking brake wire hitting my driveshaft.
Good luck in finding the problem.
Old Jan 19, 2009 | 01:14 PM
OrleanZ33's Avatar
OrleanZ33
Maybe a throw out bearing ?
Then again I see you have a lightweight flywheel installed.
Old Jan 19, 2009 | 02:24 PM
j1234's Avatar
j1234
test pipes rattling?
Old Jan 20, 2009 | 09:36 PM
ladyzed's Avatar
ladyzed
Ran over a mattress?
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
