oil pan APS, what level oil ?
Old Jan 19, 2009 | 02:26 PM
guigui79's Avatar
guigui79
Default oil pan APS, what level oil ?
hello.
I installed on my nissan 350z 280ch of 2003 "APS Air Cooled Cast Alloy High Capacity Engine Oil Pan".
I do not have a turbo. I would like to know that level of oil in the engine to be with Carter.
I read on their site but I do not know if it is only for those on the turbo.
http://www.airpowersystems.com/350z/...ain_notice.htm
"Due to the fact that the oil pickup is lowered by approx 1 / 2 inch (12 mm)
into the larger APS oil pan floor, the correct engine oil level is achieved
when the stock dip-stick reads at the low mark after being fully inserted."
thank you in advance for your response
Old Jan 19, 2009 | 03:11 PM
superchargedg's Avatar
superchargedg
Damn Noobs
1 extra quart of oil i do believe.
Old Jan 19, 2009 | 09:28 PM
guigui79's Avatar
guigui79
yes. but at what oil level on gauge ? low or hight ?
I sent a mail to APS :
hello. I installed on my nissan 350z 280ch of 2003 "APS Air Cooled Cast AlloyHigh Capacity Engine Oil Pan". I do not have a turbo. I would like toknow that level of oil in the engine to be with Carter. I read on yoursite but I do not know if it is only for those on the turbo.http://www.airpowersystems.com/350z/oil_drains/oil_drain_notice.htm"Due to the fact that the oil pickup is lowered by approx 1 / 2 inch (12mm) into the larger APS oil pan floor, the correct engine oil level isachieved when the stock dip-stick reads at the low mark after beingfully inserted. " thank you in advance for your response
They replied :
Yes the oil level should be the same, with or without turbo,
Regards,
David
I sent an email to find out why :
ok.
thank you for your speed.
but why put it at the low level ?
They replied :
To prevent the crankshaft from causing the oil to froth,
Regards,
David
but I still do not understand why put at the bottom level.....
Old Jan 19, 2009 | 09:51 PM
Spork's Avatar
Spork
It holds 1 qt more.
Total of 6 qts.
Old Jan 19, 2009 | 10:59 PM
terrasmak's Avatar
Regards,
David
You could run at the upper mark if you want , but they designed it to add an extra quart and lower the oil level from the crank (see the statement from them quoted above)Their product is for roadracing, when they set it up, they decided that for turning corners, the oil level needs to be lower.
Old Jan 20, 2009 | 03:09 AM
guigui79's Avatar
guigui79
ok.
but I use my Z but a bit on the road and especially on the track.
(me with my Z : http://fr.youtube.com/profile?user=g...10&view=videos)
so I do not know how to set the level.
those who have an APS oil pan, you put the level ?
Old Jan 20, 2009 | 04:54 AM
coachk's Avatar
coachk
With my APS pan, when I change the oil and filter I have always used 5 1/2 qts of oil which puts it right at the low level on the dipstick, and have never had a problem.
Old Jan 20, 2009 | 08:12 AM
guigui79's Avatar
guigui79
ok. thank you all.
I will put it almost at the low level.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
