Differential number help
Old Jan 26, 2009 | 08:55 AM
bovi's Avatar
bovi
Default Differential number help
I need to know where this diff is from asap
#383110c000
The higher mark wrote 2y02061
Thanks
Kevin
Old Jan 26, 2009 | 09:05 AM
gothchick's Avatar
gothchick
Picz?
Old Jan 26, 2009 | 09:09 AM
bovi's Avatar
bovi
Those are small but i cant take big shot with cellphone. By the way, its the same shape of a 350z but looks like its not the right part number. Nissan canada cant find it.
Old Jan 26, 2009 | 09:47 AM
gothchick's Avatar
gothchick
Looks right to me. Looks like it came with the traction control sensors too.
Does it have an LSD? You'll know if both axles turn when you turn only one side...
The only difference between the auto diffs and manual diffs is 3.3 and 3.54 gears respectively.
Do you have a pic of the back of the pumpkin?
Old Jan 26, 2009 | 09:51 AM
bovi's Avatar
bovi
I bought this vlsd from a member here, he told me it was 2005 vlsd. Yes when i turn one the other turns too so i guess its vlsd. Its for my base 2004. Thanks
Old Jan 26, 2009 | 09:54 AM
gothchick's Avatar
gothchick
Other than not knowing what the gear ratio might be inside, it should bolt right up...
Old Jan 26, 2009 | 10:00 AM
bovi's Avatar
bovi
Yah, but i dont really know what year it is. Nobody seems to be able to find that part number. Kinda strange.
Old Jan 26, 2009 | 10:52 AM
gothchick's Avatar
gothchick
Here's what the bolt pattern looked like on mine. Maybe compare this to yours?
As far as not knowing the gear ratio it came with, just spin the drive shaft spindle. It will either spin 3.3 times or 3.54 times per every turn of the axle stubs. Might be a good time to get 3.9 or 4.08 gears? :-)
Attached Thumbnails Differential number help-dsc02387-1-.jpg   Differential number help-dsc02388-1-.jpg   Differential number help-dsc02394-2-.jpg
Old Jan 26, 2009 | 01:02 PM
bovi's Avatar
bovi
Its a manual 6spd , i know the gearing its ok. Its only to know the year.
Old Jan 27, 2009 | 04:44 AM
gothchick's Avatar
gothchick
Okay - Well if that's all you wanna know - Then year dosesn't matter. They're all the same. Just bolt it up and have fun.
sales@czp
Sep 23, 2019 03:30 PM
35reilly
Sep 28, 2015 07:42 AM
