just reset ECU on my NISMO Z..... :(
Old May 4, 2005 | 06:56 AM
  #41
Speedracer's Avatar
Speedracer
Originally Posted by 350zroadster
Or you can get Nismo ECU which has a non-adjusting fuel map
What is this and where do you get it and will it pass US emissions?
Old May 4, 2005 | 07:28 AM
  #42
illZ's Avatar
illZ
Originally Posted by Speedracer
The fundamental issues surrounding ECU "adaptation" and power mods have to do with which are the primary regulatory parameters that the ECU is trying to control. In the case of the Z's ECU this primary regulatory parameter is the Air:Fuel ratio, since this is the main contributing factor in emissions regulations, and one of the main factors in engine detonation. If your mods significantly disrupt the air:fuel ratio from what the ECU has programmed in order to meet the ULEV emissions criteria, and/or keep the engine safe, it will regulate other parameters to compensate. Whether or not this translates to a loss in power depends on the specifics of the mods and combination of mods.
As to you feeling this change, it is probably more psychological than anything else. A few weeks after driving your modded car, you will get used to the change and will forget what the car felt like without the mods.
Excellent post.
Old May 4, 2005 | 09:05 AM
  #43
GuardianED's Avatar
GuardianED
At WOT, the ECU is in an open loop...
Old May 4, 2005 | 09:32 AM
  #44
mrZ's Avatar
mrZ
i didn't believe it either until a dealer re-set my ecu to get rid of the cel light. i wasn't expecting anything and didn't even think anything of it. but the difference was substantial. i have intake/exhaust. now i reset it once a week. yes it make a difference. read what technosqueare has to say about it on their web site. i only started looking into this question AFTER that incident so i wasn't imagining it.
Old May 4, 2005 | 12:12 PM
  #45
sisco534's Avatar
sisco534
Every week , that would get old fast. Does a full ts flash help if you have little to no mods? I know you have the rev raised to 7100 RPM but would it improve a stock engine meaning give it more power?
Old May 4, 2005 | 12:36 PM
  #46
sentry65's Avatar
sentry65
the burninator
TS can give you some more aggressive timing/fuel mappings than stock
you might still have to reset the ECU on a somewhat regular basis though.....I do
Old May 4, 2005 | 01:34 PM
  #47
GY-Z's Avatar
GY-Z
Originally Posted by Z350Lover
FairladyZ:
Whats the link to the website? I couldn't be able to get the Nismo ECU at all with the S-tune S1 engine in my car though... that is why I am running MoTeC... Nismo only sells the ECU out IF they do the engine conversion in Japan.... how crap is that?!
cheers,
richie
interesting, so there certainly is a nismo ECU offered?
Old May 4, 2005 | 03:07 PM
  #48
Speedracer's Avatar
Speedracer
Buy a Digimoto scan tool. About $200. Can do a whole bunch of diagnostic stuff with a laptop as well as resetting your ECU
Old May 4, 2005 | 03:32 PM
  #49
zxsaint's Avatar
zxsaint
Fairlady Stalker
Have one? I've been looking for other Z owners that may have one of these to compare some numbers with. If anyone else has one and wants to compare some numbers PM me. Most interested in comparing idle and WOT data logs for timing values and MAF/O2 voltages.
Old May 5, 2005 | 04:52 PM
  #50
Speedracer's Avatar
Speedracer
Yep. Got one. I'll try run some #'s this weekend.
Old May 6, 2005 | 04:54 PM
  #51
black350's Avatar
black350
so if i were to use the pedal re-set for my ecu, i will feel my jwt pop charger gains more?
Old May 6, 2005 | 05:19 PM
  #52
sentry65's Avatar
sentry65
the burninator
if you think you can actually feel the small gain it will give you......
Old May 7, 2005 | 05:22 AM
  #53
Z350Lover's Avatar
Z350Lover
There is... only if you send your engine back to Japan and have the Nismo S-tune Concept Engine Spec 1 installed BY NISMO ONLY, then it will come with a nismo ecu and probably you will have problem with the local fuel again (at least that's the case to Australia)... You can get MOST of the parts in the engine package separately, but not certain parts which include ECU.
cheers,
richie
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
