Clutch pedal dropped to the floor...wont come back up
Old Mar 5, 2009 | 06:11 PM
Z_Youlater's Avatar
Z_Youlater
Default Clutch pedal dropped to the floor...wont come back up
So today, i decided to take the car out for a ride since a few months from off shore. Anyways, i was coming to a u turn, and stop and trying to make the uturn, and at a very slow speed, clutch in and put into 1st gear. While clutch is in and in first gear, the clutch padel just sits there at the bottom floor and it wont come back up. Had to tow it home. Anyone have experienced this? Please help me out. Dealer is out of the question because i just rolled over 65xxx miles, and really dont wanna pay stearship price. Great advice would help.
Thanks for your time.
-Tu-
Old Mar 5, 2009 | 06:23 PM
vthao's Avatar
vthao
Bleed your clutch
Old Mar 5, 2009 | 06:26 PM
Changvi's Avatar
Changvi
-Tu-
It sounds like your clutch cylinder is toast. I'm 99% sure.....
Old Mar 5, 2009 | 07:20 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Did you check your fluid levels before you drove it? Since you haven't driven it for a few months it would have been a good idea.
Old Mar 5, 2009 | 07:37 PM
kyx4n's Avatar
kyx4n
is it an 07??
there is a tsb for the clutch cylinder
Old Mar 5, 2009 | 07:43 PM
Karenlee's Avatar
Karenlee
Default when this happens....someone wrote that they
got their foot behind the pedal and lifted it back up. Would that have worked or is it major stuck?
Old Mar 5, 2009 | 07:55 PM
ELITE_Z's Avatar
ELITE_Z
Happened to me a few months ago in my max, there was moisture in the clutch master and slave cylinders, had to get them replaced.
Old Mar 5, 2009 | 09:49 PM
Z_Youlater's Avatar
Z_Youlater
Thanks for helping me, the car is an 04 with 65xxxmiles. When i pull the padel back up and step on it again, same result, padel is stuck. And from what im reading and calling a crap load of poeple own Zs. They all said Slave cylinder is out, i might have to run to Stearship for this one, its not very expensive. Any other advice or opinion would and will help til i get this fix.
Again, thanks.
-Tu-
Old Mar 5, 2009 | 10:40 PM
stepuckey's Avatar
stepuckey
This happened to me, and yeah, I could lift it back up w/ my foot, but the remedy seemed to be to replace the master cylinder/ slave cylinder according to the stealership. Thank the Lord he was able to get it covered under warranty, even though I was like almost at 37,000 miles! Haven't had a problem since.
Old Mar 6, 2009 | 12:46 AM
kramykram's Avatar
kramykram
make sure your clutch line is not blown first. very easy to check. fill with fluid, jack the car up. then have someone pump the pedal while you look underneath.
Old Mar 6, 2009 | 08:15 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Clutch master cylinder, clutch line, or slave cylinder. You're bypassing fluid or losing fluid at one of those points.
Old Mar 7, 2009 | 10:22 AM
Z_Youlater's Avatar
Z_Youlater
Thank you all for your help, i checked out everything was in good shape n working order. The reason is the Withdrawal Lever Pivot broke as i read in other forums that they are made of cheap metal and they break easy...So i need to order one and put it in.
Again, thanks for your time.
-Tu-
Old Mar 8, 2009 | 06:13 AM
j.arnaldo's Avatar
j.arnaldo
That's p-e-d-a-l.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
