coolant bypass mod
Old Mar 12, 2009 | 04:08 PM
rpm06g35's Avatar
rpm06g35
Default coolant bypass mod
Hey guys I copied this from my thread over on driver. Well after several attempts to sell these things I realized it would probably be better for me to share the information rather than trying to sell and ship these things. I will only fab for local people as to be able to do the install myself. Burping of the coolant system is not an easy task. I really dont want to be responsible for someone messing up thier own car across the country. Enclosed are several pics with narations along the way. Any questions feel free to pm me. mike
full kit
driver side flange to block
driver side pipe bottom
passenger side pipe top
passenger side heater core nipple
rear cast pipe plugged
Old Mar 12, 2009 | 04:09 PM
rpm06g35's Avatar
rpm06g35
Now for the pressure testing set up.
heater core nipple hose plug
passenger side front (to radiator) plug
driver side blank flanged off
driver side hose w air fitting
driver side ready for pressure check
cast manifold w/ convertion for air (through temp bung)
cast manifold blank flanged off
rear and passenger side ready for pressure check
guage setup w/ valve
Old Mar 12, 2009 | 07:10 PM
2k6-z33's Avatar
2k6-z33
nice setup..
Old Mar 12, 2009 | 07:36 PM
bbs350z's Avatar
bbs350z
impressive how does this differ from the pathfinder coolant bypass?
Old Mar 15, 2009 | 10:31 AM
rpm06g35's Avatar
rpm06g35
The pathfinder coolant mod adds another thermostat to the back of the block. This kit actually eliminates the oil warmer, throttle body and thermostat cross over tube. With the addition of the nismo stat and an aftermarket oil cooler we have seen drops in coolant temps around 7 degrees. Basically just less wear and tear. Any questiond feel free to pm. mike
Old Mar 15, 2009 | 02:24 PM
QuadCam's Avatar
QuadCam
I run a similar set to what MIke has posted. It has been great for me too.
You have to understans why Nissan did what they did on the DE motor. Emissions testing is very important to the OEMs. The lower they can get their averages for their emtire car line, the better off they are for many reasons. SO, in an effort to improve emissions on these engines, Nissan needs the engine to get up to full operating temps as fast as possible. While an engine is warming up, it runs richer and has higher emissions levels. to speed up the warmup process, nissan did a couple things. One was the oil warmer down by the oil filter. since water temps will rise faster than oil temps, nissan used coolant flow around the oil filter area to help heat up the oil temps faster. Also, Nissan uses a radiator bypass line in the coolant system to bypass the radiator. the water that bypasses the radiator is sent right back to the cylinder heads in an effort to get everything up to operating temps as fast as possible.
the majority of high bad emissions output happens during warmup situations. So, Nissan used these 2 methods to get lower emissions rating on these engines.
I eliminated all these extra hoses, fittings, and pipes from my car so that it makes everything simpler and easier to work on. plus, it makes the engien alot nicer to look at!!!
Old May 1, 2009 | 02:12 PM
Darkknight916's Avatar
Darkknight916
Quadcam, awesome, thanks for explaining the reason for the mods. and rpm06g35 for the help in the setup! awesome write up guys.
Old May 1, 2009 | 06:08 PM
D-tuned's Avatar
D-tuned
you have pm
Old May 2, 2009 | 01:02 PM
__jb's Avatar
__jb
Z + Rear Seat
Geez... I love this mod...
Do you have to take the engine out to change the rear cast piece? I recently swapped out a knock sensor and there isn't a lot of room back there.
Either of you guys (Mike or Andrew) have any before and after pictures?
Old May 2, 2009 | 02:20 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Nice mod but i think your thread will be closed by a mod since you are not a paying vendor.
Old May 2, 2009 | 04:55 PM
__jb's Avatar
__jb
Z + Rear Seat
Read his first post.
He isn't selling anything.
He's giving his technology away.
Old May 2, 2009 | 11:55 PM
bbs350z's Avatar
bbs350z
interesting..might do this to the g. how does it fair emissions wise?
Old May 3, 2009 | 08:55 AM
QuadCam's Avatar
QuadCam
John,
the rear piece is tough in the car! I decided against doing it before I had the lift. with the lift, it is easier to get to the lower nuts on that piece. the wirring harness is in the way andmakes removing the cast crossover difficult.
With patience and perceverence, I'm sure you can do it.
Old May 5, 2009 | 03:07 PM
BrazenZ's Avatar
BrazenZ
I have put the Nissan pathfinder cooling mod while the engine was still in the car. It's a PITA but with patience it can be done. (PS I did use a lift borrowed from a friend, but I could done without it.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
SharX59
Sep 27, 2015 09:23 AM
