Bought some kelford s1 cams for my non-revup
Old Mar 25, 2009 | 03:55 PM
4drmadness's Avatar
4drmadness
Default Bought some kelford s1 cams for my non-revup
I just bought some kelford s1 cams for my car. Im really stoked about putting these on. im also gonna put better valve springs, rev-up rod bolts (stronger than non-revup DE) and rev-up oil pump as well.
Do you recommend putting anything else while my car is naked?
Anyone have kelford cams? it would be great to hear a review about these cams.
The mods i have are: jwt popcharger, z tube, motordyne 5/16 spacer, UR underdrive crank pulley, grounding wires, design chaos tb spacer, engine damper, aramid isothermal gasket, coolant bypass mod, stillen exhaust, kinetix hfc, dc headers, 3.5 pumpkin/vlsd swap, osiris tune.
Old Mar 25, 2009 | 04:33 PM
Sponge's Avatar
Sponge
Are you going to dyno before and after? I know I'd be interested in your gains as I have nearly the same bolt-ons and I'm looking at cams next.
Old Mar 25, 2009 | 04:35 PM
4drmadness's Avatar
4drmadness
I have already dynoed my car. at peak im making 255/255 hp/tq. this dyno was done after a tune at HB Speed. I will retune my car after the cam install as well
Old Mar 26, 2009 | 08:42 AM
1cockyZ's Avatar
1cockyZ
IF these are the ones that were for sale on here. If so you bought turbo cams for your N/A car? If they are the N/A cams and were listed wrong I am curious how they do. I was looking at the Kelford N/A b cams for something I am considering.
Old Mar 26, 2009 | 09:25 AM
Escobar's Avatar
Escobar
In for numbers, cams are something I am looking at as well. Keep us posted.
Old Mar 26, 2009 | 11:15 AM
4drmadness's Avatar
4drmadness
hey man, i bought the cams that were listed on this website. Are you sure kelford makes two different kinds of cams? one for N/A and for Turbo? If so, that would suck. I thought these would be great for N/A. any help would be great thanks
Old Mar 26, 2009 | 07:34 PM
Escobar's Avatar
Escobar
http://www.camshaftshop.com/home?pag...ategory_id=105
Old Mar 26, 2009 | 09:06 PM
maximariceboi's Avatar
maximariceboi
whats the duration and lift?
Old Mar 26, 2009 | 09:49 PM
OCG35's Avatar
OCG35
+1... this will make all the difference in the world.
I did a bunch of research prior to going with cams (and headers)... without knowing what you're getting into it could be all for not.
FWIW, even though I did see gains, I don’t recommend it based on cost/benefit… and for those that want to go into full build – yes I’m aware of all the performance benefits – but again, the cost associated may not be worth it (for most).
sentry65
Apr 30, 2023 03:12 PM
pslamp32
Feb 8, 2017 09:07 AM
RyansZ33
Sep 15, 2015 05:54 AM
chuquison
Dec 25, 2006 10:48 AM
