Do not buy pulstar plugs!!!!!
Old Feb 11, 2009 | 11:15 AM
eWrex's Avatar
eWrex
Default Do not buy pulstar plugs!!!!!
I am so mad at these guys!
A few months ago I neded to replace my spark plugs and decided to give Pulstar spark plugs a shot. 1 month ago I went to Austin, TX to Uprev to get my 2003 350z tuned. They asked me about the Pulstars and said they were curious to see if they really worked. We did 3 base pulls and then installed a brand new set of NGK plugs and did 3 more pulls. The results reflect the highest numbers from each set of plugs.
RESULTS:
Pulstar: 245.24 whp 231.19 lb/ft torque
NGK: 246.27 whp 232.39 lb/ft torque
So yeah, after $150 I am 1.2 hp short.
I called them up and they were extremely unhelpful and told me I was on my own, so I am posting this. I will be going to Kinkos and scan the dyno sheets after work today so you all can see.
I put them on to test them out and had them dyno'd like 3,000 miles later. I got 246.24 whp with the Pulstars on. Then we took them out
Old Feb 11, 2009 | 11:17 AM
turismo's Avatar
turismo
RESULTS:
Old Feb 11, 2009 | 11:20 AM
Nexx's Avatar
Nexx
you didnt lose horsepower, if you ran two back to back dynos with the ngk you very easily have a 1.5whp difference. i hope you didnt buy those pulstars thinking you would actually gain anything from them.
rcdash's Avatar
rcdash
Thanks for posting. That's within the margin of error for a dyno run.
savvy's Avatar
savvy
What kind of gains were you expecting from spark plugs?
Old Feb 11, 2009 | 11:41 AM
eWrex's Avatar
eWrex
they claim 5 -8 %
Old Feb 11, 2009 | 01:16 PM
Ericshere03's Avatar
Ericshere03
Since you already bought the plugs, run them for a while... see what happens and make note of your gas milage... you never know...
Old Feb 11, 2009 | 02:43 PM
jray8's Avatar
jray8
another case of false advertising on behalf pulstar
Old Feb 12, 2009 | 10:15 AM
go-fast's Avatar
go-fast
been seeing reports of plugs going bad in less the 10 k as well,thanks for doing the test though.
snake oil doesn't have to work,you just need to sell enough before the word gets out.
this product is a classic example of a marketing firm developing a product instead of grass roots development.
Old Feb 14, 2009 | 12:45 AM
Doubt if spark plugs make horsepower. Any spark plugs.
The numbers you are quoting are within the range of dyno error. In other words those differences can be read without any changes to the motor.
Old Feb 18, 2009 | 08:55 AM
runnun's Avatar
runnun
I agree do not buy them I had them on my car for 5k and when I pulled them they where all shot! burned themselves! they suck! my car was missing also. false advertising no gains all bs.
Old Feb 18, 2009 | 09:08 AM
04350ZTour's Avatar
04350ZTour
I had them for 3 weeks and it burnt them up. Tried to call and get my money back and got nothing. I emailed them and never got anything back. It burnt the ends clear off of them. All I had was a intake, exhaust, and spacer when it happened. There was supposed to be a money back thing if you wernt satisfied in a months time. Nothin but bs.
Old Feb 18, 2009 | 10:31 AM
06CPV35's Avatar
06CPV35
https://my350z.com/forum/engine-and-...tar-plugs.html
Have a friend running these...I told him I wouldn't and never will b/c of old thread link above.
So far his seem okay, but only good 50K mi (if your lucky), those $$ and proven premature failures...I'll pass lol.
Old Mar 26, 2009 | 11:32 PM
PhiSig's Avatar
PhiSig
Wheel Whore
The second time around what plugs did you go with the OEM NGK or the Iridium NGK?
Old Mar 27, 2009 | 03:17 AM
power2rice's Avatar
power2rice
I wouldn't waste time and money into spark plugs. They all do the same thing; create a high intensity spark to ignite the air/fuel within the chamber. All us engine builders already know the facts, I won't contribute to marketing gimmicks here. If you had forced induction then yes upgrading your plugs to a colder range will benefit you, but n/a setups; a properly gapped plug is perfectly fine. You need to understand that it's a placebo effect.
Also, you just stated right there why the ngk performed better. THEY WERE BRAND NEW; without any carbon deposits built up on them yet. Run them for the same amount of time and retest against some new Pulstar's. The Pulstars will have higher HP #'s again... because they're brand new without carbon deposits building up on them.
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
