Lowering Engine Bay Temps: wraps or other?
Old Mar 27, 2009 | 08:52 AM
dropsickle's Avatar
dropsickle
Default Lowering Engine Bay Temps: wraps or other?
Looking to lower the engine temps slightly on the '03 Z coupe. I'm thinking my clutch lines are getting too hot. I've got stainless lines & good fluid on the way, but was thinking I could try to cool the bay temps by wrapping the headers (oem). I've heard mixed things about header wrap causing the headers to rust prematurely, any other suggestions on lowering temps?
btw- the Engine is not 'running hot' the gauge always stays slightlyt lower than mid-mark so it's not a coolant issue or anything, just thought it could be a simple mod for precautionary measures.
Thanks
Old Mar 27, 2009 | 09:08 AM
freedonutss's Avatar
freedonutss
I wouldnt wrap the headers because I've heard that it will make them crack due to uneven heating. Getting them jet coated would be your best bet.
Old Mar 27, 2009 | 10:42 AM
SchismX's Avatar
SchismX
Vented hood
Old Mar 27, 2009 | 11:31 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
edit: nvm.
Jet coating would be your best bet ^^
Old Mar 27, 2009 | 06:36 PM
eltness350's Avatar
eltness350
The Untouchable
use water wetter in your coolant....low temp t-stat....u really wanna spend 200 on jet hot coating stock manifolds?!
Old Mar 27, 2009 | 10:09 PM
Sponge's Avatar
Sponge
Thumbs up
Wrap your clutch line in heat tape. The clutch line is very close to the headers and my clutch would go soft/stick to the floor after 45min of aggressive driving in the summer (in Cali). After 3x wrapping the clutch line all the way to the tranny I no longer have that problem.
Old Mar 30, 2009 | 02:59 AM
dropsickle's Avatar
dropsickle
Sounds like that could fix my problem. I'll wrap the new clutch lines when they get in. Yeah $200.00 on jetcoating stock headers seems a bit extreme. But maybe that means I should get some good aftermarket headers
Thanks for the suggestions
Old Mar 30, 2009 | 06:54 PM
Ruthless18x's Avatar
Ruthless18x
Nismo thermo, aftermarket rad, oil cooler.
Old Mar 30, 2009 | 06:56 PM
Nexx's Avatar
Nexx
vented hood.
3vilbunny
Jul 18, 2017 05:10 PM
