Run tranny cooler or not????
Old Apr 7, 2009 | 11:29 AM
SILKZ03's Avatar
SILKZ03
Default Run tranny cooler or not????
Hey, I got the Edge racing torque converter. From what I've read, its recommended and a lot guys on the forum are running tranny coolers because the TC runs hot. I talked to the Edge racing/manuafacturer who recommended against it. He said that stock cooler is sufficient. He designed it not to overheat. He also stated too much cool air could affect the performance and efficency, therefore not working properly as it should. Thoughts? get one just to be on the safe side?
Old Apr 7, 2009 | 12:22 PM
coachk's Avatar
coachk
I have had my tranny cooler for just over 3 years with no issues.I also have the Edgeracing TC. It only kicks the fan on occasionally(when running hard) but I think it is well worth it. I would say Yes...I live in South Florida so it gets pretty hot down here. Let me know if you have any other ?'s
Old Apr 7, 2009 | 12:56 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I would also say use the trans cooler as the factory one is very small and is made for use with the stock trans with no mods.
Old Apr 7, 2009 | 01:49 PM
SILKZ03's Avatar
SILKZ03
Thanks guys. As I read your comments and more research. I'm going to get the tranny cooler to be on the safe side. Any ideas other than privated classified ads to get one. also, I noticed that not all have the fan as you do...where did you get this type.
Old Apr 7, 2009 | 02:24 PM
coachk's Avatar
coachk
My cooler is from www.bmracing.com click on products and put in the part#
part#70298 HiTek Tranny Cooler
Old Apr 7, 2009 | 02:32 PM
SILKZ03's Avatar
SILKZ03
Thanks.
Old Apr 7, 2009 | 02:43 PM
coachk's Avatar
coachk
www.jegs.com has the same one for about 20 bucks cheaper
part # 130-70298
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
