Stock clutch HP ratings.
Old Apr 15, 2009 | 06:03 AM
halfass872's Avatar
halfass872
Default Stock clutch HP ratings.
I feel like i'm getting to the end of the line for the amount of HP and Torque my stock clutch can take. I've got about 15,000 miles on the clutch and flywheel. I have a Stillen stage 4 SC. It doesn't put out a whole lot in comparison to other FI, but i think i should be somewhere in the 300ish whp range with it. I've had no clutch issues what so ever. But i'm trying to plan ahead if needed.
Am i ok with these type of #s??
Old Apr 15, 2009 | 07:27 AM
djamps's Avatar
djamps
Your fine. Should hold up to ~400WHP as long as you're not hitting the drag strip constantly.
Old Apr 15, 2009 | 08:00 AM
halfass872's Avatar
halfass872
That's what i was hoping to hear!! Thanks!
Old Apr 15, 2009 | 05:12 PM
twitch579's Avatar
twitch579
Mine has held my N20 setup for the last 6 months at around 370/440Tq. I usually go thru a bottle a week too.
Just recently though my clutch fluid bottle is low....a sign maybe of wear?
Old Apr 17, 2009 | 12:58 PM
Q45tech's Avatar
Q45tech
Transmission, clutches, driveshafts, diffs, and half shafts are rate in torque not HP.
Old Apr 17, 2009 | 02:58 PM
halfass872's Avatar
halfass872
Good point.
Old Apr 17, 2009 | 05:43 PM
NISMO_558's Avatar
NISMO_558
Sillen stage 4 and you only have 300whp? thats kind of sad
Old Apr 17, 2009 | 05:51 PM
Jay'Z's Avatar
Jay'Z
Stillen is barely above stock torque so your great!!!!!
Old Apr 18, 2009 | 02:53 AM
halfass872's Avatar
halfass872
I guessed because i've never dynoed it. And i didn't feel like all the Stillen haters jumping down my throat for claiming higher numbers then are realistic. LOL
Old Apr 18, 2009 | 02:54 AM
halfass872's Avatar
halfass872
My butt dyno tells me stage 4 is significantly above stock torque, although probably not up to the same levels as other kits.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
