Grind when shifting into 3rd - and only 3rd
Old Apr 21, 2009 | 01:04 PM
the_dood's Avatar
the_dood
Default Grind when shifting into 3rd - and only 3rd
My Z just started to grind when shifting into 3rd gear. It seems to be the only gear that grinds at the moment. Its got just over 65k on it. It doesnt grind if i shift slowly, but it will if i shift at a normal shifting rate.
I havent been driving it very aggressive. More like moderate driving, whipping around turns, things like that.
I have been driving stick since my first car back in 2001 so i dont want anyone thing think im new to it. Also the clutch pedal is also all the way down, im not half a$$ing it.
Should i assume the worst and think its the trans?
Old Apr 21, 2009 | 01:28 PM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Most likely synchros are wearing out. Could try a fluid change and see if it helps any, might slow down the process a bit.
Old Apr 21, 2009 | 01:30 PM
the_dood's Avatar
the_dood
is that basically a new transmission or something else within the trans?
Old Apr 21, 2009 | 02:23 PM
SonicfireZ's Avatar
SonicfireZ
Had the same problem with my 03 performance with 77K. Just replaced the tranny fluid with Redline MTL made a night and day difference no more third gear synchro grind. Best 60 bucks i have spent on this car so far. Might wanna start there.
Old Apr 21, 2009 | 03:13 PM
Zstrong's Avatar
Zstrong
I have the same exact problem! Been like that since I bought it I figured it was synchros...
Old Apr 22, 2009 | 12:51 PM
the_dood's Avatar
the_dood
Not to be a smart *** or anything, but if there is physical grinding of the gear how would adding fluid stop the grinding? Or would it just postpone it for a while until the problem comes up again?
I wasnt sure on how to search google or this site but where could i get more info on the synchro problem?
Old Apr 23, 2009 | 11:29 AM
RAYZ33's Avatar
RAYZ33
Same thing happens to mine, except from fast shifts from 1st to 2nd and SOMETIMES to 3rd. So i need to shift slower in those gears and have people tailgate the hell out of me off the lights
It does tend to get a bit better when the car gets to operating temps but the problem's still there. I'll try changing tranny fluid soon
Old Apr 24, 2009 | 03:05 PM
zerosec's Avatar
zerosec
3rd gear grinding is common to all 03-04 transmissions(CD006),buy a CD009 tranny...
Old May 1, 2009 | 07:49 AM
That One Dude's Avatar
That One Dude
I have an 08... I get the same problem as well.. And it's not always during spirited driving.. It happens alot too when you shift at a normal pace...
Old May 11, 2009 | 07:47 AM
wizard's Avatar
wizard
I have the same problem!! Mine has 77K miles too.. Only happens in 3rd gear and usually only happens if i'm thrashing it!
I had my clutch and flywheel changed recently to a JWT spec and the gearbox oil was changed with this. It has made NO difference at all fyi....
Old May 29, 2009 | 05:13 PM
NMB's Avatar
NMB
I also have the same problem with my gear only in 3rd!!
only if I'm speed racing and when the gear gets warm.
My car is now in the Nissan Company and I'm waiting for them to respond.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
apex locator
Oct 6, 2015 05:58 PM
Ace2347
Sep 22, 2015 03:12 AM
