Relieve fuel pressure?
Old Apr 22, 2009 | 10:44 AM
moog's Avatar
moog
Default Relieve fuel pressure?
I know you can relieve fuel pressure by using a Cipher, but is there a way to do it mechanically? I need to swap out my injectors and don't want to mess w/ fuel squirting around.
Old Apr 22, 2009 | 11:49 AM
sloppymax's Avatar
sloppymax
Pull out the fuel pump fuse then start the car. It will start then die. I would start it once more again then pressure should be relieved.
Old Apr 22, 2009 | 11:06 PM
mthreat's Avatar
mthreat
I think the service manual might say how. Usually it says, "with CONSULT" and "without CONSULT". CONSULT is Nissan's equivalent of cipher - it hooks up through the OBDII port.
Old Apr 23, 2009 | 06:04 AM
halfass872's Avatar
halfass872
DO NOT DO THIS!! This is an ignorant, and dangerous idea!! Our fuel pump is acessed from inside the car. You do not want that and the fumes AND the open tank exposed while engaging your electrical system!!!! Not to mention you run the risk of damaging things. WTF are you thinking!! This is how people get killed. If you want be a dumbass and do this be my guest. But don't play with others lives because you don'tknow what the F' you are doing!!!!
To the OP....
Open your hood. Theres a schrader valve (Bicycle valve) with a GREEN screw on plastic cap on it on the passenger rear side of the engine compartment. Unscrew that cap. And with the car OFF AND COLD depress the little nipple like you are letting air out of your tire, while covering it with a rag. It will burp a little gas out, and that's it!
OR as soon as you remove the fuell rail, the same thing will happen. Wither way works.
Old Apr 23, 2009 | 06:11 AM
sloppymax's Avatar
sloppymax
To the OP....
Open your hood. Theres a schrader valve (Bicycle valve) with a GREEN screw on plastic cap on it on the passenger rear side of the engine compartment. Unscrew that cap. And with the car OFF AND COLD depress the little nipple like you are letting air out of your tire while covering it with a rag. It will burp a little gas out, and that's it!
OR as soon as you remove th efueal rail, the same thing will happen. Wither way works.
I must apologize for all the people I have killed in the past, all the damage I have done to the fuel systems and all the people I will kill in the future.
Old Apr 23, 2009 | 06:15 AM
halfass872's Avatar
halfass872
This is a good way too. Not as easy as just venting the valve, but easy none the less.
Old Apr 23, 2009 | 06:19 AM
halfass872's Avatar
halfass872
I must apologize for all the people I have killed in the past, all the damage I have done to the fuel systems and all the people I will kill in the future. Explain to me how the tank is open again?
WHOA!!! I SUCK!!!! Sorry man. I totally breezed through your post and thought you said to pull the fuel pump. THEN i quoted you again not realizing it was the same thread, and gave you props!!!
Whoops!!! LMAO!!!!
Old Apr 23, 2009 | 06:23 AM
sloppymax's Avatar
sloppymax
Haha, just making sure. I would never tell anyone to open a tank and pull the pump while its running. One way to make the schrader valve method easier to attach a fuel pressure gauge to it and allow it to vent that way. I was hoping someone was not bi-polar, haha.
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
