idling runs at 2000 rpm when started then decreases slowly, is that normal??
Old Apr 23, 2009 | 06:14 PM
eddytsi's Avatar
eddytsi
Default idling runs at 2000 rpm when started then decreases slowly, is that normal??
I just picked up a brand new manual 08 350Z. When I start my car, after its sits for awhile, my rpm's go up to around 2000. Then it slowly drops a bit at a time, down to about 1000 rpm about a minute later.
My question is it normal?? Thanks.
Old Apr 23, 2009 | 06:20 PM
david79's Avatar
david79
yes...when you start ur car from cold...the rpm usually will run high till it warms up then drops back down
Old Apr 23, 2009 | 07:02 PM
R350Zz33's Avatar
R350Zz33
come on man you cant be serious every car does this when it gets to operation temp or when the needle gets of the c peg it should idle at 750rpm
Old Apr 23, 2009 | 07:46 PM
eddytsi's Avatar
eddytsi
thanks for the 1st post as assurance, David.
I should have stated that i also have an 04 350Z and that does not even idle that high one bit. I'm not that stupid, I know that on any car, your rpm's run higher than normal when started, but again, it just seems like it's on the high side.
Old Apr 23, 2009 | 08:11 PM
bbs350z's Avatar
bbs350z
yea mine omly ran to the 1500 area then drops to around 750ish
Old Apr 24, 2009 | 03:07 PM
zerosec's Avatar
zerosec
relax ur car is fine
liqalu04
Jan 2, 2022 12:58 PM
Justin100
Nov 29, 2015 03:58 PM
Dymsi
Sep 29, 2015 11:32 AM
codek
Sep 28, 2015 03:03 AM
