New Built engine. coolant bleed??
Old May 11, 2009 | 11:28 AM
boostintt's Avatar
boostintt
Default New Built engine. coolant bleed??
so i just installed my new built engine. i poured coolant on the radiator, topped it off. started the car, car idles just fine... i let it idle for 10 mins the first time.. and today i let it idle again, but coolant came out of the overflow reservoir and temp was a little high... i didnt notice if the fans kicked in either...
my friend told me i had to bleed the coolant system? how do you do that? also im using water cooled turbos so i removed the bleed valve that goes on the heater core hose that comes out of the firewall.. same as the aps extreme turbo kit.
*** how do you bleed the coolant system??? please detail instructions... remember my bleed valve is not there anymore.. im using that to feed coolant to my turbos like the APS extreme twin turbo kit. ***
Old May 11, 2009 | 11:31 AM
Nexx's Avatar
Nexx
search "burp", you're not having much luck with the build so far are you?
Old May 11, 2009 | 11:38 AM
Entaille's Avatar
Entaille
you poor bastard. I was thinking the same thing. is there anything that has been pleasant and just 'worked' for you as of yet? lol
Old May 11, 2009 | 12:38 PM
boostintt's Avatar
boostintt
lol!!! you guys suck!!! no this has being a big headache!!!! my car's being down for a lil over 2 weeks.. it was only supposed to be down for a week!!!
this is the first time i ever do something like this... so far i've had many issues, but so far i've fixed most of them...
1. car wouldnt stay on... fixed: MAF wrong way.
2. needed base map uploaded to the utec... fixed: buddy of mine had the software and helped me out.
3. clutch wont come back up.. will be fixed tonight!! But tranny has to come down. appartently i installed the wrong fork on the tranny
4. coolant needs bleed??? not sure.. but im know you guys will help!!!
Old May 11, 2009 | 01:20 PM
boostintt's Avatar
boostintt
Old May 11, 2009 | 03:02 PM
superchargedg's Avatar
superchargedg
Damn Noobs
You need to have a bleeder valve some where up high in the coolant system to bleed the air out othewise you are gonna have a hell of a time getting the air pockets out.
Old May 11, 2009 | 03:18 PM
boostintt's Avatar
boostintt
ok... so how do aps extreme tt owners do this? when it requires them to remove this bleeder valve?
Old May 12, 2009 | 05:36 PM
kevinapex's Avatar
kevinapex
This worked for me, Jack up the front of the car so the higest point is the fill port, start it up, this should let the air pockets find there way the top of the system.
Hope this works, make sure you check it after a short drive(after it cools) to make sure your level is within spec. Good luck!
Old May 12, 2009 | 05:49 PM
boostintt's Avatar
boostintt
that might work!!! thanks for the tip!!!!!!!
Old May 12, 2009 | 08:07 PM
krnzzang84's Avatar
krnzzang84
that is exactly what i did for my evo8,, run your system then just top off the radiator cap. Bubble will most likely be there, there should be gap when you open it!
lapham3
Oct 7, 2022 03:15 PM
35reilly
Sep 28, 2015 07:42 AM
SharX59
Sep 27, 2015 09:23 AM
