Ok, WTF did I break now?!?!!?!? lulz. Clutch/Drivetrain Problem
Old May 24, 2009 | 07:09 PM
Nexx's Avatar
Nexx
Default Ok, WTF did I break now?!?!!?!? lulz. Clutch/Drivetrain Problem
Ok, went to the track today. Preloaded the clutch and launched at 4500. It wheel hopped a bit, I let off and get back on her. It pops out of gear and I cant get it back in gear so I coast the rest of the way knowing I screwed up something.
The car does go into gear but grinds every time. Cruising, the car seems perfectly fine. Slipping it into 1st seems to cause the worst of the grinding. I also noticed that the clutch was very very soft.
Any ideas fellas? Master slave cylinder maybe? That would explain the soft clutch and that it might not be fully disengaging....
I have zero luck at the track it seems.
edit: I actually said "FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUU U" when i was coasting down the track, ROFL!
Old May 24, 2009 | 07:17 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You need to just give me that damn car already. I'll put her into 11s and take good care of her without breaking anything.
Bump (after 8 minutes) for answers.
Old May 24, 2009 | 07:58 PM
Russ@Z1's Avatar
Russ@Z1
Have you checked for leaking fluid or dirty fluid in or around the cylinders?
Old May 24, 2009 | 08:26 PM
Nexx's Avatar
Nexx
no leaks... a little dirty around the cylinders though.
Old May 24, 2009 | 08:48 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
throw out bearing?
If you not sure, check out my video clip.
https://my350z.com/forum/engine-and-...-fly-help.html
Old May 24, 2009 | 08:58 PM
shezzzhot's Avatar
shezzzhot
Abzolutely Zexy
Dooo eettttt!!
Old May 24, 2009 | 09:35 PM
Nexx's Avatar
Nexx
Originally Posted by Chef-J
throw out bearing?
definitely not, mines a 100% cannot mistake it for grinding kind of sound.
Old May 24, 2009 | 09:37 PM
Nexx's Avatar
Nexx
throw out bearing?
definitely not, the noise my car is making is only when i shift and its 100% grinding.
Originally Posted by shezzzhot
Dooo eettttt!!
FFFFFFFFFFFFFFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
Old May 25, 2009 | 12:20 AM
kramykram's Avatar
kramykram
is it hard to shift with the car cut off??
Old May 25, 2009 | 12:31 AM
Nexx's Avatar
Nexx
doesnt seem like it.. i'll try in the morning.
Old May 25, 2009 | 06:50 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Check with Alberto. He's already been through that process.
Old May 25, 2009 | 07:27 AM
LVZ053's Avatar
LVZ053
Do you smell Clutch?
I killed my clutch at the track before and it would grind when ever I tried to get it into gear.
Old May 25, 2009 | 08:57 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Humm do you feel like clutch issue? I mean it sounds like it could be tranny. But hope not.
What clutch u running with that monster?
Old May 25, 2009 | 09:05 AM
Nexx's Avatar
Nexx
clutchmasters FX400, i'd actually be happy if it was the clutch so i can get rid of it and get something more friendly to drive.
Old May 25, 2009 | 02:04 PM
Nexx's Avatar
Nexx
no i didnt smell clutch.
Old May 25, 2009 | 09:20 PM
VO...'s Avatar
VO...
Administrator
Edited title to reflect thread content...
Old May 25, 2009 | 10:45 PM
Nexx's Avatar
Nexx
thanks VO!
I can get the car in gear when the car is off like its normal. I can get the car into gear when when the car is running but its grinding. clutch is feeling really soft compared to normal. HELP!
Old May 26, 2009 | 05:01 PM
bbs350z's Avatar
bbs350z
does the pedal return slowly?
how does the shifter feel once its in gear? is it sloppy or tight in there (no pun intended)
Old May 26, 2009 | 05:04 PM
Nexx's Avatar
Nexx
once it's in gear it feels tight, like normal. its just a matter of the terrible grinding going into gear. 1st and 2nd are the worst and it gets better the higher i go.
Old May 26, 2009 | 05:10 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It's hard to tell. Could be a clutch issue or you messed up your sychros. It's really hard to tell. My guess is the hard launch glazed your clutch, and now it's not disengaging completely, causing the grind.
