has anyone converted there tb?
Old May 25, 2009 | 11:14 PM
DudeMan's Avatar
DudeMan
Default has anyone converted there tb?
to a cable tb? just curious cant seem to find anyone that did it
Old May 26, 2009 | 05:13 AM
Z04's Avatar
Z04
Old May 26, 2009 | 04:58 PM
bbs350z's Avatar
bbs350z
would you try to convert your dvd player to accomodate vhs tapes?
whai argh teh newbz fewl ov phailz?
Old May 26, 2009 | 05:27 PM
DudeMan's Avatar
DudeMan
if vhs was better... yes
you ovbisouly dont know **** about these cars if you think that the way the throttle is controlled is fine... it closes when braking which is not good for brake boosting... it opens slow as hell and doesnt open all the way unless you have a reflash and the brake module from kpierson
Old May 26, 2009 | 11:12 PM
Gingervitis526's Avatar
Gingervitis526
I heard that you can use something from a pathfinder or something like that... but that was a long time ago and never heard anything more about it. Hope that helps some...
Old May 27, 2009 | 04:17 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
several people have
what it takes?
new throttle body, custom cable brackets routed to gas pedal, reflashed ecu to bypass the codes you will get. A new ecu (Haltech, etc) would also be in order
Old May 27, 2009 | 11:34 AM
DudeMan's Avatar
DudeMan
Originally Posted by Z1 Performance
several people have
what it takes?
i was looking into a 300zx tb and 240tb i saw some custom setups on other nissans but nothing on a z/g... i know youd need to get rid of codes but what purpose would a standalone serve with just doing a tb swap?
Old May 27, 2009 | 07:49 PM
bbs350z's Avatar
bbs350z
are you kidding? i rebuillt my entire car by myself guy. tbw in my opinion is much better than a throttle cable. get the supporting mods to bypass this, and youll be fine.
btw if your turbo'd wouldnt you want a standalone? so hurry up and sell your utec, get the haltech, and follow what z1 said.
Old May 27, 2009 | 08:37 PM
DudeMan's Avatar
DudeMan
did you actually assemble the motor and measure clearances? dropping a motor in a car in my opinion is not building it.. completely not trying to be a dick
im not planning on doing it was jw i have an sts turbo now but im going with a s480 and lq4 setup with a th400
Old Jun 1, 2009 | 02:28 PM
bbs350z's Avatar
bbs350z
haha in that case no lol i didnt "build" it lol, but everything else was done by myself. im just trying to see the logic in this? audibly mayhem i believe ran a th400 in his, and sp is doing it to vlad's g35. id contact sp and see how theyre handling it, then again, theyre on pro-efi ems
Old Jun 1, 2009 | 03:58 PM
DudeMan's Avatar
DudeMan
im ditching the vq motor all together and going lq4(iron lsx) i can get a complete running long block for under $500 and stock they can take 700whp like nothing. the only thing that sucks is either making my own custom braces or ordering hinsons which ive heard lots of bad things about so idk yet on which route im going for that
Old Jun 2, 2009 | 03:57 PM
Z&G's Parts Dis's Avatar
Z&G's Parts Dis
Vendor - Former Vendor
check out AUTECH TSUKADA.... they did it
http://www.jdm-option.com/eng/featur...2/z33_v35.html
Old Jun 6, 2009 | 11:55 AM
bailey bill's Avatar
bailey bill
When the throttle plate closes, it INCREASES manifold vacuum. Deeper vacuum increases the assist from teh brake booster.
bill
Old Jun 6, 2009 | 05:03 PM
DudeMan's Avatar
DudeMan
bill
so i guess youre not boosted... because if so you would know that it will lower your tp which will lower fuel also...
Old Jun 7, 2009 | 06:05 AM
bailey bill
So what does boost have to do with vacuum to the brake booster? When you lift and the TP closes, you ain't boosting.
BTW, when you lift and the TP closes, the ECU shuts the injectors off, so yeah it lowers fuel, but when the throttle is closed, you obviously don't need fuel.
bill
Old Jun 7, 2009 | 04:22 PM
DudeMan's Avatar
DudeMan
do you understand what brake boosting is?
norrix420
350Z Roadster
May 23, 2022 05:11 PM
sales@czp
Sep 23, 2019 03:30 PM
ejv8s10
350Z Roadster
33
Jun 14, 2016 08:31 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
