Can someone PLEASE identify this noise
So im getting a noise in my Z now. It happens when realeasing the clutch and making a slow start. As im releasing the clutch and the car is starting to move, I get a weird, low frequency chatter, or grind (sounds kinda like somethings being dragged) It starts once the clutch starts to grap and stops once I get going. On quick starts you cant really hear it cause engaging first happens so fast. You hear it underneith, and a little behind you (thats where its SOUNDS to be) So im pretty sure its the tranny, but I don't know what. Is my clutch burnt? Is my flywheel damaged? Is it something normal that I just noticed at 13,000 miles?
I had something somewhat similiar, turned out to be a tiny rock inside between the rotor and the pad. It could be the same thing for you, take a hose and spray it hard onto the rotor and caliper.
It's possible the noise is occuring at higher speeds but the engine sound and road noise is covering it up.
wanderingstuden
Jan 28, 2016 07:03 PM
