ARC V2 oil catch can drain direction
Old Jul 7, 2009 | 08:40 PM
Changvi's Avatar
Changvi
Default ARC V2 oil catch can drain direction
I sort of have an idea on how to drain the oil from the ARC V2 oil catch can, but i just wanted to confirm it before i go ahead and drain the oil out. How exactly do you drain the oil from it?
Old Jul 8, 2009 | 05:25 AM
MR RIZK's Avatar
MR RIZK
At a guess u take the hoses off and tip it upside down
Old Jul 8, 2009 | 09:10 AM
VO...'s Avatar
VO...
Administrator
+1
I have the same catch can. I haven't drained it to-date. There's a few hoses on it, and it would be nice to know the exact way to drain it to minimize the amout of work that has to be done.
Let me know what you find out. Take pics if you can also...
Old Jul 8, 2009 | 09:12 AM
JZurita's Avatar
JZurita
The way I've been doing it is tipping it sideways using the arm it's attached to. I take off both hoses and let it drain into a ziplock bag.
Old Jul 8, 2009 | 09:21 AM
VO...'s Avatar
VO...
Administrator
So the 2 hoses on the passenger side of the can are what you detach? Which hose does the oil drain from? There's also a tiny little pipe on that side also, which has a rubber plug on it. What is that for?
Old Jul 8, 2009 | 10:07 AM
JZurita's Avatar
JZurita
The small clear rubber hose on that side is so you could check the amount of sludge collected and when it's time to empty out the can. The oil comes out mainly from the hole farthest from the front, but I just take both off to be sure.
Old Jul 8, 2009 | 10:44 AM
VO...'s Avatar
VO...
Administrator
Thank you very much sir!
Old Jul 8, 2009 | 05:50 PM
Changvi's Avatar
Changvi
Ah ha, thanks very much for the answer I've been looking for. So just to confirm, the oil drains from the clear rubber hose, which, is the furthest from the front, or through the crank case hole?
Old Jul 9, 2009 | 01:07 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
are you guys NA? If so, if you have to drain it, you've got a major issue going on
in the 3 years I had my ARC (v1), I never once had to take anything out of it
Old Jul 10, 2009 | 04:18 AM
JZurita's Avatar
JZurita
< FI
Old Jul 10, 2009 | 05:30 AM
VO...'s Avatar
VO...
Administrator
I don't know about any of the other guys, but I'm NA. I have no idea if it needs draining or not. I'd just like to know how when the time comes...
Old Jul 10, 2009 | 06:55 AM
Z1 Performance
Former Sponsor
you'll should never have to, so don't worry about it If it fills up, yank the engine, time for a rebuild, at which point, the catch can is the least of your problems unfortunately
Old Jul 10, 2009 | 06:59 AM
Changvi's Avatar
Changvi
What kind of problems are associated with oil in the catch can? Mine gradually filled up about 1/2 in the duration of 7+ months. And it has now since stopped.
Old Jul 10, 2009 | 07:02 AM
Z1 Performance
Former Sponsor
it's an indication of blow by, which generally has a root cause of worn, or wearing rings
if it was there, and somehow stopped, I can't answer what that might be, unless you changed the hose routing somehow in that time
Old Jul 10, 2009 | 07:06 AM
Changvi's Avatar
Changvi
No, i have never changed any hoses or what not. Always the same position since I installed the catch can. Could the blow also by caused by excess engine oil during oil change? Meaning 1/4 to 1/2 quart over standard.
Old Jul 10, 2009 | 07:09 AM
Z1 Performance
Former Sponsor
I'd be surprised if that little excess oil caused that much accumulation, but anything is possible suppose
Old Jul 10, 2009 | 07:22 AM
Changvi's Avatar
Changvi
OK, thanks for the info. How do i check to see if my rings are worn? The car was never FI'd or anything.
Old Jul 10, 2009 | 07:25 AM
Z1 Performance
Former Sponsor
get a compression test done
Old Jul 10, 2009 | 07:26 AM
Changvi's Avatar
Changvi
Cool. Thanks Adam...
kyin
Oct 15, 2015 05:54 AM
VO...
Aug 4, 2012 07:14 AM
NA350Z
Dec 9, 2006 03:03 AM
kevinapex
Apr 17, 2006 06:53 AM
