Help! Weird Noise at low RPMs
Old Jul 16, 2009 | 03:31 PM
eNdiT's Avatar
eNdiT
Default Help! Weird Noise at low RPMs
Hey all - I've noticed a weird noise (sounds like metal shaking or grinding) when I am at low RPMs or when I downshift. It sounds like CUSHHHHHHHHCHSHCHSH
It doesn't happen when Im cruising or at higher RPMs...but I can't figure it out. It sounds like its coming from the engine or under the car. I jsut had an oil change and everything works fine on the car ...just the annoying noise?
Anyone have or hear of this problem before? THanks!
Old Jul 16, 2009 | 05:11 PM
matix101vz's Avatar
matix101vz
nice onomatopoeia
Old Jul 17, 2009 | 07:04 AM
absurdparadox's Avatar
absurdparadox
Hard to say. I would first try to determine if its make the sound only at a certain traveling condition, or at a certain RPM. Try to figure out if its engine speed or car speed related. That will put you on a path to start hunting for it.
If it is engine speed, get someone to hold the RPMs where it makes the noise and try to point the sound. I'll used a long tube to listen through, to isolate areas.
Old Jul 17, 2009 | 07:27 AM
only350z's Avatar
only350z
I think this just happen to me but it went away after a day.
Never happened before, so random.
I heard the noise when I was doing a smooth, slow acceleration toabout 4 RPMS and higher. It was like what the OP originally stated. Can't describe it too well but it was pissing me off!!
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
