350z idle
Old Jul 24, 2009 | 07:47 AM
kappa88's Avatar
kappa88
Default 350z idle
Hi guys,
some time ago i was working on the engine of my z. When I put everything back together and fired the engine I noticed that when I am in gear and rev the idle at first goes to 1400 rev for a second or two and only then it goes to the normal 1000. I can't remember if it use to do it before as whell or not.
Is it normal???
tnx
Old Jul 24, 2009 | 07:57 AM
Elan's Avatar
Elan
Hmm...my idle is about 700 or 800 RPMs...Sometimes when I rev it a bit, it hits like 1200 pauses for a second then continues down. So yeah I think it is pretty normal. Could be that the RPM needle needs some oil. Happened to a buddy where the needle would get stuck and actually froze at one point.
Old Jul 24, 2009 | 09:46 AM
PerfZ's Avatar
PerfZ
Isn't 1000 RPM higher than "normal"?
Old Jul 24, 2009 | 10:03 AM
03threefiftyz's Avatar
03threefiftyz
my idle has been bumped 200rpm over stock and idles at 900. 1000 is high.
Old Jul 24, 2009 | 01:30 PM
vthao's Avatar
vthao
The idle is computer controlled. If it's high, check for any vacuum leaks.
Justin100
Nov 29, 2015 03:58 PM
codek
Sep 28, 2015 03:03 AM
05UltraYellow
Sep 24, 2015 05:41 AM
Inspatatrac
Sep 8, 2015 02:12 PM
Darkspy
Sep 7, 2015 09:09 PM
