Oil Cooler
Old Oct 3, 2003 | 05:37 AM
Iezzi's Avatar
Iezzi
Default Oil Cooler
Does anyone else make an engine oil cooler other then Nismo?
Old Oct 3, 2003 | 10:32 AM
N74DV's Avatar
N74DV
any quality oil cooler will work. You want one that has AN or NPT style fittings and you'll want to use Aeroquip aircraft hose.
I'm going to put one in mine before next summer. I plan on using an aviation oil cooler. MUCH cheaper than Nismo unit at the quality is better too.
What I haven't figured out yet is where to tap into the oil system. There must be a plug in the engine now that is removed when you install the oil cooler.
Old Oct 3, 2003 | 01:13 PM
jesseenglish's Avatar
jesseenglish
Use a thermostatically controlled sandwich adapter, that fits between the block and your oil filter.
Old Oct 3, 2003 | 02:30 PM
exploder's Avatar
exploder
I just got an oil cooler from an old starion and cleaned it up a bit and shot it with black paint... I am going to get under it tonight and see if I can find anywhere to tap into it.
Old Oct 4, 2003 | 10:30 AM
dchi_t's Avatar
dchi_t
hey exploder, the old starion oil cooler u found, is it really small? cuz i found an 89' starion oil cooler on ebay and it seems real small, and how r u installin it? r u using the sandwich adaptor?
Old Oct 4, 2003 | 03:20 PM
cheeves's Avatar
cheeves
www.perma-cool.com
Sandwich adapter..thread size m20-1.5.
I was checking out mounting options today..pretty tight up front, especially with Injen CAI. Maybe above PS cooler, Or a dual cooler for both?
Old Oct 4, 2003 | 04:47 PM
Dissolved's Avatar
Dissolved
I was disspointed at the lack of an oil cooler in the 350. Hopefully something more affordable than Nismo's will come out
Old Oct 4, 2003 | 04:59 PM
N74DV's Avatar
N74DV
Originally posted by cheeves
www.perma-cool.com
the Perma-Cool solution seems enticing.... I like the sandwich adapter setup. I wonder of the Z has enough room for the filter to be pushed out a couple of inches to allow this method.
Old Oct 4, 2003 | 05:53 PM
EnthuZ's Avatar
EnthuZ
Kids.....have fun with your oil coolers!
From what temps are you cooling? To what temp? How are you measuring the temps? What temp does YOUR oil like? Etc.....
Sorry, but throwing money/parts at a probable nonexistent problem seems..........silly.
BTW....I LOVE purty SS braded lines with shinny red & blue fittings!
Been there. Done that. An oil thermostat that froze open.....oil NEVER reached operating temp. A stone "took out" my cooler....how do you spell NO OIL PRESSURE?
Please keep me posted as to your findings.
Old Oct 4, 2003 | 06:10 PM
N74DV's Avatar
N74DV
well I can tell you that out here in Arizona where road temps can exceed 150 degrees, an oil cooler for the Z is a good thing.
It's also VERY wise to run a bypass valve in case the cooler becomes clogged.
I plan on doing mine right using all aircraft parts. I have a nice setup on my plane that I will essentially duplicate on my Z.
I'm going to use an FAA certified oil cooler with AN fittings and Aeroquip hose AND a bypass valve..... even with all the aircraft parts the cost will be about half of the Nismo unit.
Old Oct 4, 2003 | 08:54 PM
Dissolved's Avatar
Dissolved
let us know about when you get it done pprkut@comcast.net
Would like to check it out.
Old Oct 4, 2003 | 09:39 PM
N74DV's Avatar
N74DV
Originally posted by Pure Tremble
let us know about when you get it done [email]
I'll be putting up a post when it's done. Won't be until late spring though.... it's gonna start cooling off here soon and won't really be needed, but before next summer's scorching heat comes I'll get it done.
I'll be sure to take pics.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
