How to make the 350z auto trans stronger
Old Aug 5, 2009 | 03:27 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I still ask the same ? why would the OP need a rebuild diff-pumpkin as it has no impact on the trans.
Old Aug 5, 2009 | 04:52 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Your getting to specific to the transmission here. Obviously he wants to make the Auto trans perform better. Although the diff is not part of the transmission, it EFFECTS his transmission via shorter gear ratios, therefore quicker moving through 1-2-3, which is a problem with the auto seeing as how we only have 5 gears, and 3.2 f/d as opposed to the m/t's 3.5.
In fact, THE ONLY is shorter shift points. (the effect you feel anyway) When most speak of wanting to make their tranny better, usually anything that effects shifting and therefore pickup is prob included in this, seeing as how thats the overall point of beefing the tranny, right? To help with the car performance wise, not reliability wise?
OP - what did you mean by "you want to make the tranny better"?
Old Aug 5, 2009 | 05:07 PM
GeauxLadyZ's Avatar
GeauxLadyZ
I guess its subjective. To me, anything that effects the transmission is considered "making the auto tranny better." and giving the tranny closer shift points i consider "helping make the transmission perform better."
Old Aug 5, 2009 | 08:28 PM
terrycs's Avatar
terrycs
Originally Posted by skarakis007
Where can i buy anything to make the 350z auto trans stronger
like clutch's & shift kits.
The basics are trans cooler and VB upgrade w/shift kit. Both make the AT more reliable by keeping fluid temps down.
The trans cooler disapates heat in the fluid to atmosphere and the VB upgrade w/shift kit decreases the time the transmission is "in between" gears which is when most of the heat is generated in the fluid.
Old Sep 11, 2009 | 06:38 PM
ImWeeZzel's Avatar
ImWeeZzel
stillen makes the vb upgrade as well. i have one and i am satisfied w/results. i would have to agree w/ the rest of the guys as far as trans cooler. those you can find anywhere, hell autozone carries universal ones.
the vb is an easy install but remember where your bolts go because they are different sizes, it helps to take pictures of what you are taking apart. 12 bolts and three wires or 1 wire hold the vb in place. gl w/ your upgrade.
http://www.stillen.com/product.asp?i...SAN&model=350Z
Old Feb 17, 2010 | 02:07 AM
350Zdj's Avatar
350Zdj
hey guys, sorry for reviving a dead thread but...
I've got a customized VB upgrade and it works only @ WOT and upshifts. (i mean i can only feel the quicker shifts @ WOT)
Is it the same for GTM / Stillen???
Old Feb 17, 2010 | 10:15 AM
rcdash's Avatar
rcdash
No. It is very clear that shifts are crisper even daily driving at low rpm/throttle - you can feel every shift. Gear shifting is no longer transparent, not bad at low revs/throttle but not seamless. All depends on how much the line pressure was raised and what parts were modified... For example, I don't think any of the kits do anything for the 4-5 shift.
Old Feb 17, 2010 | 11:04 AM
350Zdj's Avatar
350Zdj
ah. you're the man, when it comes to these types of questions rcdash! thanks much!
Old Mar 22, 2010 | 09:52 AM
ipodhustle's Avatar
ipodhustle
http://www.summitracing.com/parts/TRG-RE4R01A-HD2/
is that the right one? says it's on backorder too..
Old Mar 22, 2010 | 11:15 AM
dirtbikr's Avatar
dirtbikr
That's obviously not the right one considering it says it's for a 4-speed.
the one you want is the RE5R05A-HD2
Ace2347
Sep 22, 2015 03:12 AM
_koubie_
Sep 20, 2015 06:34 PM
hardkicks
Sep 20, 2015 12:28 PM
