DIY Engine Oil
Old Aug 4, 2009 | 07:42 PM
xthejokerx's Avatar
xthejokerx
Default DIY Engine Oil
Hi guys, I remember there used to be a thread on here for DIY oil change, but I can't seem to find it.
Anyways, I've read another tutorial and it says to buy a new drain plug. Now, I want to make sure... We use a new drain plug every time we change our oils, but keep the drain bolt correct?
Also, is the oil filter removable by hand without having to use the oil filter wrench?
Old Aug 4, 2009 | 07:45 PM
03aeroZ's Avatar
03aeroZ
Bolt=plug....the crush washer should be replaced (debatable)
Old Aug 5, 2009 | 12:11 AM
Sponge's Avatar
Sponge
I'd buy a oil filter wrench. Nothing like being under the car and having to drive a screw driver through the filter cuz its stuck. Costs < $5, worth every penny when you need it.
Old Aug 5, 2009 | 06:53 AM
VO...'s Avatar
VO...
Administrator
+1. Like stated above, the crush washer is debatable. I've never replaced mine. It's been 6 years.
+1
Old Aug 5, 2009 | 06:56 PM
xthejokerx's Avatar
xthejokerx
Appreciate the informative replies.
Old Aug 5, 2009 | 07:28 PM
*ICE*'s Avatar
*ICE*
best $20 I ever spent on mod.
Fumoto Quick oil change valve. No mess and no worry about changing the washer every time.
http://www.qwikvalve.com/home.php
Old Aug 6, 2009 | 12:56 PM
WhiteNoiz's Avatar
WhiteNoiz
Oil Change DIY
1. Remove undertray (phillips screwdriver)
2. Remove oil cap
3. Drain oil/drain plug (wrench/metric)
4. Replace oil filter w/ new one
5. Replace drain plug
6. Pour 5.1 qts of oil in the fill hole (where you took the cap off)
7. Replace Oil cap
8. Start, check for leaks
9. Replace undertray
Done
Old Aug 6, 2009 | 01:59 PM
03aeroZ's Avatar
03aeroZ
I don't even take off the undertray. I just wipe up the small mess I make with the change, never seemed worth it to take off the tray (and you think the dealership takes the tray off??)
Also, why 5.1? The owners manual says 5 with a filter change (03)
Old Aug 6, 2009 | 02:08 PM
WhiteNoiz's Avatar
WhiteNoiz
I used to not take off the undertray until I did take it off. Makes it much cleaner and easier, plus I can inspect my belts at the same time.
just checked the manual, yup, 5 with filter change. Dunno where I got the .1
Old Aug 9, 2009 | 11:29 PM
xthejokerx's Avatar
xthejokerx
Does anyone know what the filter wrench size is for the oil filter?
Old Sep 10, 2009 | 04:56 PM
yogipower's Avatar
yogipower
Originally Posted by WhiteNoiz
Oil Change DIY
2. Remove oil cap
7. Replace Oil cap
Done
^+1 Thanks you (:
Old Sep 11, 2009 | 01:36 PM
MDK's Avatar
MDK
I just use a large channel lock wrench to get the filter off. A medium size wrench is all you need to get around that dinky filter.
Old Sep 12, 2009 | 11:06 AM
j.arnaldo's Avatar
j.arnaldo
VERY 1st STEP: Elevate the Z onto jackstands, THEN follow steps 1 thru' 9, above! The use of chocks is HIGHLY recommended, if doing it on a slight incline, such as a driveway (my case).
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
