Oil stick reading
Old Aug 16, 2009 | 03:02 PM
cachinbombete's Avatar
cachinbombete
Default Oil stick reading
You guys don't know how much i'm hating that oil mesuring stick on the 350z. I just changed the oil for the first time, I dripped all the oil for a long time, remove the filter and open the measuring stick (however i did not open the oil cap until the filter and plug were tided in place. I would like to believe i put 4.5 quaters. The 5 quarts container or valvoline SAE 5W-30. has lines on the sides for liters and quarts. The actual container with some oil left, it's between the bottom of the container and the first line. I checked the oil stick and it's all cover withoil beyond the H level. I can not get a good reading since it takes a lot of turning and bending to get it out or to put the stick back on place. What can i do to check the appropiate level of oil. Could it be posible that I over filled with oil???
Old Aug 16, 2009 | 03:06 PM
jeffie7's Avatar
jeffie7
Dry it off, stick it back in then pull it out, when looking at it, hold it at an angle and tilt it under a light, at some point you'll see where the "wet" stops. If you still can't see it lay it down on a white paper towel and look at where the towel gets wet.
Yes its a PITA, the only good thing is after a week or so of driving the oil will have enough color to easily see on the dip stick.
Old Aug 16, 2009 | 04:23 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
You need to run the engine for awhile after oil and filter change. You can't measure properly until the filter has absorbed however much it is going to absorb.
Old Aug 16, 2009 | 04:35 PM
mclovin.too's Avatar
mclovin.too
Let it sit over night and then check it. (cold engine)
Old Aug 16, 2009 | 04:56 PM
cachinbombete
Default Unknown quatity of oil
Since it could be + or - 4.5 quarters, what happens if there is to much or not enough. For sure there is like half of a quarter on that 5 quarter container, unless valvoline uses Imperial quaters and i usually put to much since i put 4.5 quarters of that container
Old Aug 16, 2009 | 05:09 PM
quakerroatmeal's Avatar
quakerroatmeal
I use 5qts. all the time.
Old Aug 16, 2009 | 06:08 PM
terrasmak's Avatar
5 quarts and your good.
Old Aug 16, 2009 | 06:31 PM
Welcome to the dipstick from hell!
Old Aug 16, 2009 | 06:54 PM
cubs4worldseris's Avatar
cubs4worldseris
^ haha
Old Aug 17, 2009 | 06:00 AM
cachinbombete
Default imperial quarts??? or US quarts
so put the entire containner it says 5 quarts on that synthetic valvoline container. I got it from walmart for 22$. I don't think it's imperial quarts right??? I has to be US quarts.
Old Aug 17, 2009 | 07:11 AM
quakerroatmeal
I think you're over thinking it
Old Aug 21, 2009 | 07:05 AM
Lee R's Avatar
Lee R
The only way I can get an accurate reading is to drain the oil and then measure it. The way an HKS supercharger is wedged in there does not help at all either.
Old Aug 21, 2009 | 09:13 AM
j.arnaldo's Avatar
j.arnaldo
Will there actually be any kinda damage to the seals, rings or gaskets IF you do overfill?? Just a doubt, dudes.
Old Aug 21, 2009 | 02:17 PM
exZilaration's Avatar
exZilaration
5 quarts will do just fine
Old Aug 21, 2009 | 04:34 PM
jeffie7's Avatar
jeffie7
Is this about reading the dip stick, or when to check the dip stick for a correct level?
Get the car up to temperature, park on a level surface and let the car sit for a few minutes then check. I like mine to be near the top of the markers. I always put in slightly less then what's needed and add more if needed. I over filled a car once and had to jack it up and slowly let oil out the drain plug, it was a PITA, so I'll never over fill again.
Old Aug 24, 2009 | 11:18 PM
TRAVONthePHENOM's Avatar
TRAVONthePHENOM
I bought an 03 Z in march with 48k on it,switched to synthetic,now i have been hearing a lifter knock type of sound when i cold start it in the morning and the other day the oil psi gauge was down to 0 and the oil light on the dash came on,i checked the stick and there was nothing on it!! almost bone dry, anyone know what the prob could be? it doesnt leak a drop and the mileage is too low for problems,but i dont know how it was treated by the previous owner,maybe they beat the **** out of it for the the first 48k?
Old Aug 25, 2009 | 07:34 AM
terrasmak's Avatar
burning oil , it happens. Mine burns about 1/2 quart every 2500 miles.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
