Crank Bolt Question
Old Aug 23, 2009 | 07:26 PM
Zazz93's Avatar
Zazz93
Default Crank Bolt Question
What do you guys use to break the seal on your crank bolts? I'm using an impact wrench rated at 400 Ft/Lbs and I can't break it. I was going try and pick up one rated at 710 Ft/Lbs but if you guys have found better way to loosen those up its appreciated.
Old Aug 23, 2009 | 07:38 PM
rrmedicx's Avatar
rrmedicx
WD40.
Just double check: are you referring to the flywheel bolts that secure to the back of the crank? Stock is only 70 or so ft/lbs. How many miles on your car? Careful not to strip them.
Old Aug 23, 2009 | 11:47 PM
Zazz93's Avatar
Zazz93
Sorry wrong bolts, I'm refering to the Crankshaft pulley and bolt. Tried WD and it seems to have had no effect. I also wanted to make sure this crankshaft didn't spin in an odd direction and require a reverse bolt.
Old Aug 24, 2009 | 11:29 AM
vthao's Avatar
vthao
Get a bigger impact and shoot that bad boy right out
Old Aug 24, 2009 | 02:22 PM
Zazz93's Avatar
Zazz93
Got it done! Took a bigger Impact Wrench and a lock on the shaft to stop it from moving at all.
