engine torque damper
Old Sep 30, 2009 | 07:31 PM
ECLIPSEGST25's Avatar
ECLIPSEGST25
Default engine torque damper
i have looked at some write ups but none really good. anyone know hoe to install a engine damper on a 2005 350Z?
Old Sep 30, 2009 | 08:09 PM
Jay'Z's Avatar
Jay'Z
Its simple...
http://www.stillen.com/product_files/307355~inst.pdf
Old Sep 30, 2009 | 08:18 PM
dhays's Avatar
dhays
Originally Posted by Jay'Z
I must be mentally challenged, but I read the instructions and didn't feel they were all that clear. Of course, maybe if I was actually looking at the engine bay in the process....
More important questions: Are the dampers effective at dampening engine rotation, and does this really do anything to improve drivability or performance?
I had engine torque dampers in my RX-7. There it was helpful since the car had original engine mounts. Shifting was tighter without as much engine movement under hard throttle. Not sure about the Z though.
Old Oct 1, 2009 | 05:35 AM
GeauxLadyZ's Avatar
GeauxLadyZ
This is from Z1 Performance website, and this particular damper is the best made for the Z imho...but either way this pretty much sums it up well:
Ingalls Stiffy Engine Torque Damper 350Z
A self-contained elastomeric shock that mounts on brackets between the engine and the chassis. It reduces extreme engine movement and dampens the motion, providing many benefits. The “Stiffy” was originally intended for the sport compact market, but can be used for some Hot Rod applications if it is applied correctly.
Benefits
Greatly improved off-the-line acceleration
Reduced wheel hop
Improved vehicle stability
Reduced shock loads on driveline components
Smoother shifting
Reduced wear on exhaust system joints
Less vibration transmission to the driver compared to polyurethane motor mounts.
Less shock load, compared to torque straps and chains.
Drifting – helps reduce shock loads when wheels gain traction.
Reduces motor movement – decreases the chance of motor parts rubbing against
the hood and frame.
Old Oct 1, 2009 | 06:38 AM
Kwame's Avatar
Kwame
The Stillen instructions are sufficient enough once you have the parts in front of you and you are standing in front of the car. I speak from experience as I installed this piece on my own personal car back in '04 or'05.
My unbiased review is that the only noticeable difference that I saw after installation of the Stillen damper was reduced wheel hop, that is about it. I have since sold it and instead have opted for solid motor mounts (obviously a much more involved install compared to any of the engine dampers on the market). Would I personally purchase the engine damper again for my own car? No, but that is me (main reason being I'm not a fan of the aesthetics of a damper in my engine bay as I find my eyes are drawn to it each time I'm looking in the engine bay).
The Ingalls unit posted above looks to be a better (and pricier) unit than the Stillen and thus far we have not heard anything negative from the customers who have purchased one from us.
Old Oct 1, 2009 | 06:52 PM
dhays's Avatar
dhays
Thanks to both Kwame and GeauxLadyZ for the information.
Old Jan 20, 2013 | 09:47 PM
mike_eee's Avatar
mike_eee
Here is my set-up, found new locations, fabbed a sheet metal part and did my own..
Attached Thumbnails engine torque damper-damper-1.jpg   engine torque damper-damper-2.jpg
liqalu04
Jan 2, 2022 12:58 PM
3vilbunny
Jul 18, 2017 05:10 PM
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
