Problem with Build
Old Nov 23, 2009 | 04:53 PM
Zazz93's Avatar
Zazz93
Thanks rr,
Your rebuild blog helped out with some things as well so thanks on that note as well.
Old Nov 30, 2009 | 10:17 AM
Zazz93's Avatar
Zazz93
Just when I thought I was out of the woods... I finished the motor again and now there is still a lack of power (although better) but there is now a poping backfire. The back fire is odd because is doesn't seem to increase at the same rate the revs increase. For example at idle it pops once ever 2-3 seconds and at 3000 rpms it pops at nearly the same the intervals. One good thing that has come from the re-timing is the fueling is in line and no longer dumps fuels right out of the cylinders. Also the ECU is no longer adjusting the fuel trims bank 1 and 2 show 0% adjustment.
As for the timing I thought I got it on the mark this time. Everything lined up really well and had no slack in it. I must be having a little yellow bus moment because I can't figure this out.
Old Nov 30, 2009 | 02:55 PM
Z_ology's Avatar
Z_ology
Your fuel trim numbers sound good! Do you have any codes now? You may have to take it for a spin if it is drivable for codes to appear.
Old Nov 30, 2009 | 05:27 PM
Zazz93's Avatar
Zazz93
Yeah, its still sporting a P0300 - Random multi-cylinder miss-fire. Barely drivable and it is still getting a lot of fuel directly on the cat causing it to heat up.
Old Dec 1, 2009 | 06:43 AM
Zazz93's Avatar
Zazz93
Ok guys,
I really did have a "Little Yellow Bus" moment and missed the correct assignment of the 4 and 6 coil harness wires. I couldn't imagine the short wire goes the longer distance but it does and it works. The sounds great and runs really smooth. So after about 20-30 extra hours of work I find that it could have easily been corrected in 10 mins. That's the way it goes. I'm happy and thanks for the help.
The Finished Project...
Old Dec 1, 2009 | 06:51 AM
rcdash's Avatar
rcdash
Originally Posted by rcdash
Coil pack mix up?
Originally Posted by Zazz93
Ok guys,
Too bad the coil packs are not clearly numbered from the factory. I will definitely put labels on mine before I pull them off again. Glad you got it to work, but that was a lot of extra work!
Old Dec 1, 2009 | 03:24 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Happy to see you got this all sorted out.
Old Dec 1, 2009 | 03:33 PM
Zazz93's Avatar
Zazz93
Yeah I thought you meant something else but you hit on the head all along. Thanks for the input.
Old Dec 1, 2009 | 05:44 PM
binder's Avatar
binder
they're not? my coil wires have white tags with black numbers on them all.
Old Dec 1, 2009 | 06:52 PM
Zazz93's Avatar
Zazz93
I think mine used to have those tags but heat and time have made them useless.
Uriyo_
Sep 8, 2021 08:46 AM
