Tomei 268 Cams
Old Oct 15, 2003 | 02:42 AM
mjedens's Avatar
mjedens
Default Tomei 268 Cams
Does anyone know all the numbers (lift,ect.) for the 268 cams? I received a set and they come with absolutely no paperwork! I jumped the gun and now not sure if this will be the best setup for what I'm doing!!
Old Oct 15, 2003 | 05:13 AM
350zSpeedRacer's Avatar
350zSpeedRacer
Check with the shop you bought them from. If they don't know or can't get ahold of Tomei, you might be able to find a race shop that can read the cams for you.
But whatever you find out, post it up! I've been trying to find out the specs for two months now. Oh and if they work with the stock valvesprings.
Old Oct 15, 2003 | 05:49 AM
g356gear's Avatar
g356gear
After talking to SGP they say you can use the stock valve springs with the 268's. They do have heavy duty springs available for $350 (JWT) and titanium retainers for $495. I am planning on using the 268's and springs and retainers are on my list as well.
Tomei specs Mild 256 duration, 10.2 mm lift
Med 264 duration, 10.2 mm lift
Race 268 duration, 10.5 mm lift
Nismo 262 duration , 10.2 mm lift
Old Oct 15, 2003 | 06:06 AM
PhoenixINX's Avatar
PhoenixINX
Default Re: Tomei 268 Cams
Mike... have faith. I think you're going to LOVE these cams.
LOTS of top end power, you'll suffer down low, but we'll make up that loss with some of the bottle!
If you don't like em... sell em to me!!!!
I'm still checking on injectors for you!
Old Oct 15, 2003 | 11:08 AM
mjedens's Avatar
mjedens
Angry 268 Cams
Thanks to those that responded!! I did know the lift already , but my engine builder was interested in all those other #'s (which mean nothing to me). Yes , I went ahead & got the retainers and springs-why not since I'm this far into it!!
CHRIS: Yea, I'm with you! Update: Took yours and Doug's advice and stopped thinking lower compression! It would have killed me to have a dog on just motor!! Received today the 11.5:1 Forged pistons & rods and having someone locally make them into 10.5:1!! Cams should work well with this compression!! Switched N20 kits and still think I can run a little more juice but safer!! Went ahead & got the JWT flywheel and when it's a dog in 60 ft.- it's your fault!! Mike
Old Oct 15, 2003 | 12:34 PM
spazpilot's Avatar
spazpilot
mjedens
I hope your not planning on any FI. It may not work well.
Old Oct 15, 2003 | 12:47 PM
PhoenixINX's Avatar
PhoenixINX
Default Re: 268 Cams
Mike,
You know I still could never get launching your car. ANYTHING else, no prob... but those SLICKS are SICK!!!
Does bluefish have a lil' competition on the horizon? I think so!!!
Old Oct 15, 2003 | 02:56 PM
mjedens's Avatar
mjedens
Default Spazpilot
If by FI you mean "Turbo or "S/C" , I realize this setup ( cams & 10.5 pistons) would not be good! Hardest decision I've made in a long time !
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
