Rev up motor vs non rev up motor
Old Dec 16, 2018 | 03:24 PM
  #41
Michael Johnson's Avatar
Michael Johnson
Default Rev up vs non rev up
How can I tell the difference between the rev up and non rev up, I have an 06 rev up with a blown motor, been searching for a while and trying to get a rev up isnt simple. And going online it's hard to tell the difference from a rev up to a non rev up. If yall could help me that would be most appreciated.
Old Dec 16, 2018 | 04:31 PM
  #42
BluestreamDE's Avatar
BluestreamDE
Holy hell did you not read the thread you JUST commented in?
Old Dec 16, 2018 | 04:59 PM
  #43
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I was thinking his horrible first post just got moved here by a mod.
Old Dec 18, 2018 | 11:02 AM
  #44
Cracka350's Avatar
Cracka350
This thread is the forum equivalent of Jurassic Park.
Old Jul 11, 2019 | 01:24 PM
  #45
masterjr33's Avatar
masterjr33
did you just pick a random thread to revive?..
Old Jul 11, 2019 | 01:42 PM
  #46
eZg's Avatar
eZg
You prolly want to post in the forced induction section.
Just my 2 cents. Find a used engine or get IPP built one:
https://www.importpartspro.com/vq35d...-packages.html
Old Jul 11, 2019 | 10:19 PM
  #47
260DET's Avatar
260DET
Geez, this thread is full of off topic intrusions that make reading it a nightmare, people need to take more care and consider others before jamming their question into the middle of a conversation. Selfish, very selfish.
Old Oct 9, 2022 | 04:59 AM
  #48
terpmaster's Avatar
terpmaster
i have a problem well not a problem but more like i cant tell kinda thing so my tachometer says rev and it has 7,000rpm redline but i have 2005 enthusiast model 350z now i decoded my vin number but it tells me i have a 35th anniversary! But none of the package that comes with it so Im confused if i have a rev up engine or regular
Originally Posted by dyna962007
Ok guys, from reading this forum, It seems therse are the facts.
The 2003-2004 model motors were non rev up type producing like 287HP.
The 2005 and 2006 model years uses the higher reving motor producing 300HP.
The 2007 and 2008 used a 307HP but with slighlty less torque, not sure if its a Rev up motor or not.
My question is this, just exaclty what is the internal differences in the motors from 03-08 that are responsible for this increase in RPM red line and overall increases in HP.
Common sense would dictate that it might be Throttle body size increase, Caming, changes in the ECU, chaanges to the intake etc etc.
But we should be able to identify these changes and then hopefully incorperate some of them into the old motors.
ALso I was told today, there was a problem with the older motors, 03-04 in the rod bearing area. It seem there is a stretching of the rod or main bearing bolts??
Anyone have any input on any of these points? Thanks, Mike
Old Nov 23, 2022 | 12:42 AM
  #49
martin231_day's Avatar
martin231_day
The de is the weakest of them all but the fact that the 06 cars weigh nearly 200 lbs more almost makes them equal. But when it comes to power adders a revup is going to see better gains than de.
Old Nov 23, 2022 | 03:21 PM
  #50
DarkZ03's Avatar
DarkZ03
The very few hp will pale in comparison to the torque differences. There's a reason the MREV2 is based on the DE lower half and often used on the revup.
thebuffalo11
Apr 16, 2010 09:05 AM
AgentReaver
Aug 14, 2009 12:43 PM
tchesney
Aug 27, 2008 02:48 PM
Fear's Track 06
Mar 30, 2006 02:01 PM
