3.90 Drive Gear
Old Nov 9, 2009 | 06:17 PM
easternriderkid's Avatar
easternriderkid
Default 3.90 Drive Gear
has anyone put the 3.90 gears on there n/a hr motor? just looking for some input from the pros or anyone for that mater
Old Nov 9, 2009 | 07:37 PM
hellsoldiers08's Avatar
hellsoldiers08
Cons would be higher rpms when on the high way :/ and little shorter gearing. Is it auto or stand because some people with auto would say 4. something gearing but if you have standard then people would say 3.9 if i remember all this correctly. Try searching and you should be able to find a couple threads on the subject.
Old Nov 9, 2009 | 07:45 PM
pchio's Avatar
pchio
Search!
Old Nov 9, 2009 | 08:12 PM
easternriderkid
Originally Posted by pchio
Search!
i did search the parts im just looking for info from people that have it in the car thats allpros and cone from people that drive them all the time. trying to get all info before buying. and yea its a manual trans
Old Nov 9, 2009 | 10:43 PM
_Donovan_'s Avatar
_Donovan_
https://my350z.com/forum/engine-and-...installed.html
https://my350z.com/forum/drivetrain/...-in-stock.html
here are two threads that may help. I too am looking to do this mod. From what i have found, it seems the 4.08 gears are the best choice. Slightly better performance and cheaper. which means more money for a LSD or the install. The best place to start looking for more info is in the 350Z tech area, then search 3.9, 4.08, or gears.
Good Luck
Old Nov 9, 2009 | 10:46 PM
_Donovan_'s Avatar
_Donovan_
And another thing, if you are serious about improving your car's performance then gears would be the best start.
Old Nov 10, 2009 | 05:43 AM
onagao's Avatar
onagao
... unless you're trying to improve straight line performance after 1st gear. That won't be any quicker.
(every gear will have more torque and pull harder, but it's effectively negated in a straight line by the fact that you must shift earlier)
Old Nov 10, 2009 | 01:18 PM
easternriderkid
that is true i do alot of auto cross and pairing the gears with the ultra light flyweel ans stage 2 cluch thats in the car should shave time off the clock
Old Nov 10, 2009 | 03:44 PM
onagao's Avatar
onagao
Yeah, around the track, gears should turn your car into a beast with all that newfound available torque and the better utilization of your powerband.
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
