Drain Plug Washer problem...
Old Nov 14, 2009 | 06:36 PM
Panu's Avatar
Panu
Default Drain Plug Washer problem...
Do I need to change drain plug washer evertime when I change an engine oil?
Thxs ahead..
Old Nov 14, 2009 | 06:38 PM
03aeroZ's Avatar
03aeroZ
no.
mclovin.too's Avatar
mclovin.too
It is recommended and they are dirt cheap from Nissan.
But chances are it will not leak if not replaced.
Old Nov 14, 2009 | 06:39 PM
krnzzang84's Avatar
krnzzang84
recomened!!
purpose of plug is to prevent oil leak, I reused them couple times but i will just replace them!
They are only 30 cent
Old Nov 14, 2009 | 06:40 PM
03aeroZ's Avatar
03aeroZ
I have never replaced mine on an 03 with no leaks
Old Nov 14, 2009 | 06:55 PM
s31t8n8's Avatar
s31t8n8
you dont have to replace it everytime but its a good thing to do. The next time you go to the dealership just buy a few or go to you local auto part store and buy one
Old Nov 14, 2009 | 07:01 PM
VO...'s Avatar
VO...
Administrator
Moved.
I've never replaced my washer, but a lot of people do. No leaks so far...
Old Nov 14, 2009 | 07:25 PM
Black Z Eddie's Avatar
Black Z Eddie
My 06 leaks without it.
Old Nov 14, 2009 | 08:06 PM
dirtbikr's Avatar
dirtbikr
Do you screw it in by hand?
I've reused mine several times, and just replace it when I remember... No problems thus far.
Old Nov 14, 2009 | 09:06 PM
diablox1's Avatar
diablox1
just buy like 100 of them at once for $30, and replace them every time. takes a few seconds to swap them off of the drain plug. i replace mine every time, and u'd probably be alright if you don't. but $30 is a pretty cheap re-assurance investment over the life of the car.
Old Nov 14, 2009 | 10:26 PM
Black Z Eddie
Yup, screw off screw on.
I while back, when I first changed my oil, I didn't use a washer and leaked about the size of 2 quarters after driving. Not extremely bad, but annoying. So, now, I put on a new one every oil change just to be on the safe side.
Old Nov 15, 2009 | 07:20 AM
terrasmak's Avatar
Havn't replaced mine yet in the past 60k, never replaced them on past cars, wasn't recomended to change it in past cars. Can't see why there would be a change.
Old Nov 15, 2009 | 08:03 AM
INTIMAZY's Avatar
INTIMAZY
They are perfectly fine to reuse. Just visually check to see that its in one piece.
Old Nov 15, 2009 | 09:29 AM
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
You should replace them. That being said, I never have, and have never had the slightest bit of a leak.
Old Nov 15, 2009 | 07:54 PM
tware's Avatar
tware
My dealer doesnt even have them to sell : / wtf? If you use 28-30ft lbs like youre supposed to, they wont deform enough to need replacement that often. I buy them 10 at a time and replace them every 4-5th change.
Old Nov 16, 2009 | 07:22 AM
SRT8-Jeep's Avatar
SRT8-Jeep
I change them...just because when I asked if they had them at the dealership they gave me a handful for free
Old Nov 16, 2009 | 07:31 AM
tware's Avatar
tware
One of our crappier local dealers had some available.. for like a $1 of pop. Wtf? Anyway, they only said they had some because they had some leaks... Leaks? I asked them if they were using air tools on the drain plugs, which of course they were, insisting they had torque sockets that would prevent over torque. Ummmm, yeah.. they were destroying those crush washers, but you can't tell those guys anything.
Old Nov 16, 2009 | 08:18 AM
halfass872's Avatar
halfass872
+1 Always went to the stealership with the intentions to pay, always was just given a bunch for free.
Why not change it? Don't be cheap!
Old Nov 16, 2009 | 08:52 AM
Asterix's Avatar
Asterix
Or, you could put in a Fumoto valve and never worry about it again. Flipping a lever is so much better than removing a plug, it's worth every penny.
Asterix
Old Nov 16, 2009 | 09:35 AM
halfass872's Avatar
halfass872
Asterix
No offense, but do you change your oil everyday? Why in the world would you want to make it that easy to drain your oil?? That seems like a huge risk to take just because someone wants to save the 30 seconds or less it takes to remove the plug. You already have to remove a million 10mm screws to pull off the plastic cover to get to your drian plug. What's one more??
IMO a drain is about the dumbest thing you could do! There's a reason no cars come with this option. Could you imagine if it was to come open while you are driving?!?!?!
