UR Pulleys: is it OK to use 3/8" longer belt than specified?
Old Oct 16, 2003 | 01:53 PM
MY350Z.COM's Avatar
Default UR Pulleys: is it OK to use 3/8" longer belt than specified?
I tried AutoZone and O'Reilly's Autoparts but none have the A/C Belt I need. Both had a 3/8" longer belt.
Will this work?
It should be fine as long as the tension is correct right?
I need a response ASAP, cause I'm about to put them on.
Thanks,
Victor
Old Oct 16, 2003 | 02:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
yep - won't matter as long as you can get the right tension adn your adjsutment bolt is not maxed one way or the other - you'll be fine
looks good witht he powdercoated wheels never saw that before
Old Oct 16, 2003 | 02:19 PM
MY350Z.COM's Avatar
thanks, it was done by photoshop specialist
Old Oct 16, 2003 | 03:43 PM
Z1 Performance
Former Sponsor
hehe..really?
Old Oct 16, 2003 | 04:09 PM
all_bark's Avatar
all_bark
I am about to go get my belts also.
Does anyone have the belt #'s that I need to go get?
thanks.
Old Oct 16, 2003 | 04:10 PM
Sosa's Avatar
Sosa
To get the crank bolt off simply, hold your wrench on the bolt, and have somebody crank the car, but not turn it all the way over. It'll pop loose like magic and with a rack, u should be able to do it within about 45 mins for all of them. Have fun.
Old Oct 16, 2003 | 05:19 PM
spazpilot's Avatar
spazpilot
thanks.
Gates #'s
Alternator Gates: K060445
A/C Gates: K040353
Congrats on your mod
Old Oct 16, 2003 | 05:22 PM
spazpilot's Avatar
spazpilot
your kidding right!!!! Soundsdangerous to me. How about if he puts the car in 6th gear(whlie its off) and uses a breaker bar. That worked for me. Starting the car is just not safe to me!!
Old Oct 16, 2003 | 06:08 PM
all_bark's Avatar
all_bark
Originally posted by spazpilot
Gates #'s
A/C Gates: K040353
thanks
Old Oct 16, 2003 | 07:41 PM
350ed's Avatar
350ed
Professional
You can get them for $20 + shipping from www.rockauto.com
Just search for the part number.
Old Oct 16, 2003 | 08:30 PM
MY350Z.COM's Avatar
really? sounds kinda crazy to do that.
Old Oct 16, 2003 | 10:24 PM
Sosa's Avatar
Sosa
Negative. Just don't turn the engine all the way over. The 5 mechanics at the dealership where my bro works, and 3 mechanics i know who tune & have been doing this stuff for a long time said it's one of the #1 tricks. Dunno, I guess the 9 mechanics don't konw what they are talking about tho?! Especially since my pulleys got done in 45 mins, whereas almost everybody else is taking 2 to 6 hrs.
Old Oct 16, 2003 | 11:51 PM
spazpilot's Avatar
spazpilot
All I have to say is what happens if you turn the key and the bolt doesn't break loose. Bang there goes your fingures, hand and what ever else breaks on your body. I would rather have it take two hours then hurt myself. It also only took me 45min-1hr to install. So yes I would say your nine machanics are wrong. By the way here is a link to the install from UR racing themself.
http://www.unorthodoxracing.com/inst.../04100150_.pdf
Old Oct 16, 2003 | 11:55 PM
spazpilot's Avatar
spazpilot
SteaminRice:
I just wanted to clear something up. I am not saying it won't work, just very unsafe. Be careful man, don't do something because someone told you, follow the directions its your best bet.
Old Oct 17, 2003 | 07:06 AM
peptidbond's Avatar
peptidbond
WHOA!
First, do NOT use a longer AC belt. The one that is recommended will work, but it requires that the tensioner be extended all the way. If the belt loosens with time, you will not have enough tensioner room left to tighten it. If anything, use a shorter belt. I used a shorter belt and with the tension cranked down to spec, the tensioner pulley was in the middle of its total travel. This wll allow me to tighten it or loosen it if anything changes. A longer belt would be problematic at the least.
As for cranking the engine to loosen the belt, I would highly recommend against this. Hell, it might work, but it would be dangerous. The bolt is easy enough to get off using the regualr method and an 18-inch breaker bar. Just go the safe route.
Mike, if you have questions for someone who has done this install, just shoot me a PM.
Old Oct 17, 2003 | 07:26 AM
Z1 Performance
Former Sponsor
that is the most dangerous thing I have heard of for an install - its not a hard bolt to get off at all. Put the car in a high gear, and just use a breaker bar, it will come right off for you.
peptibond - yours was all the way extended? We used the recommended size on an install here, and still had some room on the tenisoner - just goes to show each car can be a bit different sometimes!
Best bet Victor is maybe get a size smaller and larger than recommended, then return the one you don't use...this way you don't get stuck!
Old Oct 17, 2003 | 08:41 AM
MY350Z.COM's Avatar
whew! glad i didn't do the install last night, now where can i find this damn gates belt!! I want to do it this weekend!
Old Oct 17, 2003 | 09:53 AM
spazpilot's Avatar
spazpilot
Don't know if you have one but I bought mine at Hi-Lo Autoparts. I think it was 37 bucks for both. Any autoparts should have them though. Good luck on your install.
Old Oct 17, 2003 | 10:05 AM
failsafe's Avatar
failsafe
....for your health
Vic- If you can't find them locally you can order them from Courtesy:
http://www.courtesyparts.com/Merchan...t_Code=0410015
Old Oct 17, 2003 | 12:12 PM
MY350Z.COM's Avatar
doh! i'm an idiot, it is 3/8" shorter, I don't know why i thought it was longer.
it should work then.
thanks!
