Enthusiast LSD into Base?
Old Dec 6, 2009 | 08:23 AM
cjgsxr2002's Avatar
cjgsxr2002
Default Enthusiast LSD into Base?
Will this bolt right up? What would be needed? Tried to search nothing came up.
Old Dec 6, 2009 | 09:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
at a minimum
both shafts
both output shaft bearings
new ring gear bolts
new output shaft seals
we offer an install kit for this type of thing if you want
https://my350z.com/forum/vq35hr/4319...base-350z.html
or, buy a full, complete pumpkin from an LSD equipped car - just be sure to recognize that manuals and auto's have different final drive ratios. Full pumpkins interchange between manual and auto cars, but the individual components inside (the ring and pinion and differentials) are different between manual and auto cars, and cannot be mixed and matched. Manual LSD's can only be used with the manual ring and pinion ratio and auto LSD's can only be used with the auto ring and and pinion ratio
Old Dec 6, 2009 | 12:52 PM
duro78's Avatar
duro78
Stock lsd sucks if your gonna do it do it right
Old Dec 7, 2009 | 08:11 AM
nismonian's Avatar
nismonian
wont quafie lsd's drop right in?
Old Dec 7, 2009 | 07:51 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
If you are referring to a stock VSLD into a base? If you buy the whole VLSD pumpkin it will bolt right into place of the base pumpkin.
_bit
Oct 2, 2015 07:49 AM
350z82
Oct 1, 2015 06:25 PM
