Need to replace engine, will a G35 Coupe Motor Be a Direct Swap?
Old Dec 23, 2009 | 12:50 AM
detailaddict's Avatar
detailaddict
Default Need to replace engine, will a G35 Coupe Motor Be a Direct Swap?
Hey guys, I picked up an 03 Z that needs a new motor. Anyway, I've had trouble finding a decent 350z motor for a good price. Will a 2003 G35 coupe motor fit without problems? Will it be a direct swap, regarding any wiring/sensor hook ups? Is the power output the same? Thanks in advance.
Old Dec 23, 2009 | 02:09 AM
duro78's Avatar
duro78
Everything is the same. both cars have to be mt or auto. Theres only 3 variations of the vq at least in the G and Z. DE, revup, almighty hr.
Old Dec 23, 2009 | 05:56 AM
halfass872's Avatar
halfass872
FYI this motor in the G is rated at 280HP vice 287 for soem reason. But i'm pretty sure it's the way the G computer is tuned, not the engine. So i'd imagine as long as you are still using your Z computer, then you should be ok as far as power output is concerned.
Old Dec 23, 2009 | 06:00 AM
detailaddict
Great, thanks guys.
I was under the impression that the transmission doesn't matter?
Old Dec 23, 2009 | 06:03 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You will have to swap
Wiring Harness
AC Compressor
Oil pressure senor
Everything else is direct swap
This is assumming you are not trying to swap a Revup motor into a DE car
Old Dec 23, 2009 | 06:06 AM
detailaddict
Wiring Harness
AC Compressor
Oil pressure senor
Thank you, looks like I should be able so save a few $100 going with the G35 motor then. Just to confirm, does the transmission matter?
Old Dec 23, 2009 | 06:16 AM
halfass872's Avatar
halfass872
He's not puttign a rev up in. He's doing a DE -> DE swap. One for one. Except the donor motor is out of a G not a Z of the same year.
Old Dec 23, 2009 | 06:35 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
No. A 5AT motor will have a adapter(not sure the technical name) mounted on the crank for the flexplate but it can be removed.
Old Jan 20, 2017 | 08:29 AM
DarrellG's Avatar
DarrellG
Hi there i wanted to know if the VQ35 short block from a 04 g35 coupe will go into a 03 g35 sedan. I was told that I need to replace the engine because of a compression issue.
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Vigman
Nov 17, 2015 04:34 AM
seagrasser
Oct 11, 2015 03:27 PM
