Driveability on a Transgo Kit + GTM TC combo?
Old Dec 28, 2009 | 09:56 PM
350Zdj's Avatar
350Zdj
Default Driveability on a Transgo Kit + GTM TC combo?
Hi guys my A/T is about to get rebuilt soon. I was just wondering if I might as well install the GTM TC and TransGo kit altogother while im at it. Is this advisable?
Some people are saying the combo will give me violent jerks on every gear change but I expect that on a VB upgrade. Others say it will ruin my gears in the long run. They do not have first hand experience so I'm not fully convinced.
Therefore I am asking for your enlightenment. Any opinions? advise?
thanks a lot!
Old Dec 29, 2009 | 05:41 AM
stillettoDSM's Avatar
stillettoDSM
From what I've read, the TransGo Kit provides strong, firm shifts while in "Sport" mode, but a normal feel while driving in "D".
Old Dec 29, 2009 | 06:55 AM
GT-Z's Avatar
GT-Z
Its ganna shift harder in sport mode cause it pops it in gear faster, when in d mode it ride's on the clutch's a lil then goes in gear.
Old Dec 29, 2009 | 07:01 AM
rcdash's Avatar
rcdash
I would not recommend a high stall converter without a nice big transmission cooler and without a specific need for a high stall converter. Daily driving will feel "mushy" as the stall increases. The VB will be civil at low throttle but crisp at high throttle/rpm. If you are rebuilding the transmission, I would put in the high performance clutch packs, etc. GTM does the full upgrade and I highly recommend it. I did not personally like the high stall originally set and I went to something lower (but still higher than stock). I am FI pushing about 500 wtq though. If you are NA, I would get the stage 3 GTM-5AT but without the TC upgrade (normally includes the VB upgrade).
Old Dec 29, 2009 | 07:24 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
When I bought Ron's car and was driving it it drove fine with the transgo kit and tc. It's exactly what you'd expect. Harder shifts in manual mode and smooth shift in auto mode. Slowing down every once in awhile you could feel the down shift but nothing outta control
Old Dec 29, 2009 | 12:25 PM
350Zdj's Avatar
350Zdj
well first of all thanks a lot for all your feedbacks!
i just found out i only need a TC with slightly higher stall speed than stock, since i track(circuit) my Z once in a while. I've already got the AT Cooler.
Hi RCDASH, GTM has a performance TC in their website. Any idea what's the stall speed on that one? it's not mentioned anywhere
Old Dec 31, 2009 | 05:32 PM
fabre80's Avatar
fabre80
I can assure you that the Transgo kit on D drive runs as good as stock, but as soon as you put it for manual it becomes another car. Great fast shifts with chirp wheels and all. This is one great mod for A/T guys!! Also i would suggest buying or investing in shorter gears, maybe a swap on a 3.5 pumpkin.
Old Jan 1, 2010 | 11:41 AM
superchargedg's Avatar
superchargedg
Damn Noobs
I bought Matts(zul8r) valve body and its been great.Its smooth when driving normal but kicks a$$ when getting on it and im sticking to the stock TC.
Old Jan 1, 2010 | 02:43 PM
350Zdj's Avatar
350Zdj
good stuff!
After reading your posts i went and talk to the shop's manager regarding the kit. He told me that the kit is best used with high performance clutchpaks, else the oem ones would wear out very soon.
just wanted to know if this is just a marketing gimmik? how many miles have guys been running the kit?
Nevertheless, the transgo kit sounds like an awesome mod. im going to get them installed.
thanks again!!!
Old Jan 1, 2010 | 05:07 PM
rcdash's Avatar
rcdash
If you are rebuilding the transmission, there is no reason NOT to use the high performance clutch packs!
The GTM TC I believe is a 3200 rpm stall at WOT if you are pushing stock power. At 500 wtq the stall was closer to 4500 rpms. (Stall is a function of input torque).
Old Jan 2, 2010 | 08:30 PM
350Zdj's Avatar
350Zdj
thanks for the info!
Hi Perf. cluck packs are ordered, in addition to the VB upgrade. Everything should be done by Monday
Has any1 by any chance heard of the AT specialist called Dexol? These guys have the main branch in the US so they claim.
Old Jan 3, 2010 | 05:31 PM
fabre80's Avatar
fabre80
Do the install man its worth it, also like i said above try to get a Pumpkin from a manual and its even better then. Also make sure the oil enough because i had a few quarts missing at the beginning and it jerk the tranny nasty. good luck is all worth it.
EnjukuRacing
Sep 30, 2015 06:55 AM
