VIDEO - Help! Engine does not start.
Old Jan 13, 2010 | 09:17 AM
huyrua's Avatar
huyrua
Dealerships can reprogram your transponder for you.
Key cutting is taking a blank key and cut (grind) grooves into it to fit the lock. Yours are already cut. Your transponder is a little chip that needed to be reprogram. PM me if you have any other questions.
Old Jan 13, 2010 | 09:28 AM
musubi's Avatar
musubi
Has the gas been sitting in your tank for 3 months? If so, might want to siphon it out and replace with fresh gas. Just a thought.
Old Jan 13, 2010 | 10:03 AM
deffe's Avatar
deffe
Its like 1 meter snow over here. the car got summer tires. Hard to get to a Nissan Dealer (assuming that the car needs to be at the same place as the key where it is programmed)....
... Cant I do this myself somehow ? Im not afraid of some hard work...
Old Jan 13, 2010 | 10:28 AM
huyrua's Avatar
huyrua
It's not a "do it yourself thing". The tool is very expensive.
Old Jan 13, 2010 | 11:01 AM
deffe's Avatar
deffe
Hmm the transponder. Where is it located?
Also is there a way to bypass it (and how)?
And Im able to open and lock the doors and such with my current keyremote, but you belive I still need a reprograming ?
Old Jan 13, 2010 | 11:27 AM
SageZ's Avatar
SageZ
The transponder is a chip "inside" the key. A programmed key is needed to start the car and drive it (if this is the problem). If you can't get to the dealer, a good locksmith can program the key.
Old Jan 13, 2010 | 11:53 AM
deffe's Avatar
deffe
Ok, but do I have to get the car to the locksmith or the locksmith to the car or can they be programmed on diffrent locations?
I suspect that the only way to program the key is to read the signals from the car?
Old Jan 13, 2010 | 12:07 PM
rcdash's Avatar
rcdash
If there is a key mismatch/ecu/security issue, the security light will come on and stay on (on g35s anyway).
Cam and/or crank position sensor or MAF sensor failures are also possibilities.
Any CEL codes that you can read with the key ON (but not cranking or started obviously with an OBD reader)?
Old Jan 13, 2010 | 02:26 PM
huyrua's Avatar
huyrua
350z do not have security lights and the car will cuts right off, not enought time to notice any CEL light
Old Jan 13, 2010 | 05:03 PM
F34RL355's Avatar
F34RL355
there is a DIY for programming the remote search for it. as for the key you have to go to a delaership are there nissan dealerships in sweden? i sure hope so
Old Jan 14, 2010 | 12:24 AM
deffe's Avatar
deffe
Ive just done an ECU reset. Without any results.
I will proceed with the "DIY for programming the remote" as soon as i find the thread.
Im googling the remote DIY at the moment so, that will be my next step if possible.
Old Jan 14, 2010 | 08:26 AM
deffe's Avatar
deffe
I am able to unlock/lock the car using the remotecontrol that came with the keys. And I assume that the "FOB" is the one you recommend me to program.
But I doubt that would have anything to do with this since I am able to remotly lock and unlock the car allready...?
Old Jan 15, 2010 | 12:41 PM
350ztxn's Avatar
350ztxn
yeah check the transponder..i had a problem with the icb,but your pump is turning on so that cant be it
Old Jan 15, 2010 | 08:28 PM
R350nate's Avatar
R350nate
if you are able to unlock/lock the car its not the battery.
if you can turn your key to the on position without cranking it, to where the dash lights turn on, you can buy an OBD-II port code reader. they cost around $40 USD and see if any ECU codes are tripped
something is messed up with the ECU.
Old Jan 16, 2010 | 10:06 AM
deffe's Avatar
deffe
I just tried with the OBD reader. But since I have allready cleared the ECU once before Im unable to read old error codes.
But when I try to read the new errorcodes I do get One. But it is a very strange error..
It says "1. 2: 0" on the first line.
I assume that the number 1 is for "error 1" the first... But the 2: 0????
What on earth does that mean?
Old Jan 18, 2010 | 05:46 PM
laurentj23's Avatar
laurentj23
Bad alternator
Old Feb 2, 2010 | 12:07 PM
deffe's Avatar
deffe
Hi all I have just connected the car with another ODB2 reader/sensor and software and I got this error reported to me:
P1122
(P1122 Electronic Throttle Control Actuator)
Has anybody else had this error before and how hard is it to fix it?
Going to google this but all suggestions and pointers are welcome!
Old Feb 2, 2010 | 12:59 PM
  #38
CAB350z's Avatar
CAB350z
Do you know if your throttle body is stuck open? or is it able to move at all?
Old Feb 2, 2010 | 01:22 PM
  #39
deffe's Avatar
deffe
Interresting question..
I just ran down to the car. dissmounted the intake and tried to move the throttle with my fingers. I was UNABLE to get it to move at all. I used about just as much power as I dared to. Since Im not sure which way the throttle opens I tried to push it "both ways".
Its stuck. Is it supposed to be possible to move the throttle by hand at all since it is electronicly controlled ?
Old Feb 2, 2010 | 01:55 PM
  #40
rcdash's Avatar
rcdash
I would not think so and I wouldn't recommend it with the new one you are going to have to buy...
