quick questions -UR crank pulley install
Old Jan 15, 2010 | 04:22 PM
Vas_Z33's Avatar
Vas_Z33
Default quick questions -UR crank pulley install
Hey fellas
I decided to give this a try today, but I didnt get to finish. I followed up on 2 threads on here on how to install it..
The usual.. 6th gear, step on the breaks and a breaker bar..
Unfortunately Iam not having any luck with it. When I tried that method the crank pulley moves thus not letting me loosen the bolt.
Any ideas how to get this thing off?
when loosening the bolt, do you go counter clock wise like the rest? or is it clock wise ( I didnt put too much force in it so I didnt ruin anything but wanted to double check )
Thanks!
Old Jan 15, 2010 | 04:35 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
ur pulley and vortech = not a good combo!!!
you could always try the breaker bar on the ground and use the starter to break the bolt loose.
cheater bar as well?
Old Jan 15, 2010 | 05:01 PM
Vas_Z33's Avatar
Vas_Z33
^ vortech is sold. no more vortech lol.
What about the starter? how does that work?
Old Jan 15, 2010 | 05:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
basically you jack the car up, put a breaker bar/socket on the bolt. Lower the car a bit and use the starter to turn the motor. The bar needs to engage the ground and point towards the drivers side iirc. You click a few times and it should break the bolt loose.
Is the pulley stock and never changed?
Old Jan 15, 2010 | 06:43 PM
Vas_Z33's Avatar
Vas_Z33
The pulley is stock.. Never changed it. I did spray some WD40. I read somewhere that I should put the key to ON position? and not actually start the car... by click you mean.. starting it and then backing down again for just a sec?
Thanks for the help!!
Old Jan 16, 2010 | 12:57 PM
RAYZ33's Avatar
RAYZ33
If that doesn't work, i've heard some people heating up the stock pulley with a blow torch
Old Jan 17, 2010 | 12:33 AM
shiftdrift06's Avatar
shiftdrift06
I broken bolt acouple times and work for me.
Ebrake, 6th Gear, Pedal Brake + Breaker Bar w/ cheater pipe over it.
Old Jan 17, 2010 | 06:41 AM
Vas_Z33's Avatar
Vas_Z33
^ Ive tried that and a long pipe on top.. never worked...Im going to try n heat it up
Old Jan 17, 2010 | 01:14 PM
shiftdrift06
Well good luck to you!
On my friends 240sx, it was a PAIN!, couldnt get it off with that method, BUT
Removing Radiator + Impact Wrench rated 550torque = Off in seconds literally.
Old Jan 17, 2010 | 02:07 PM
Vas_Z33's Avatar
Vas_Z33
If I have to remove the radiator..i'm gonna just sell the damn thing lol
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
NYGiants0186
Sep 8, 2015 10:37 AM
